Home > Technical (L322) > 4.4 TDV8 MAP sensor |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I did with no ill efect. 2012 TDV8 Black Edition
19th Sep 2019 10:54am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
I have cleaned my MAPF sensor several times with spray brake cleaner, seems to work well.
20th Sep 2019 7:22am |
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 |
During an idle moment I removed the MAP sensor from the inlet manifold and even though I thought the car was going well, The sensor in the manifold was a solid lump of carbon , lots of brake cleaner later and re installed it with aa smear of silicon grease on the o ring . then starting up what difference ! idle improved and it went much better or was it all in the mind ! .
27th Aug 2022 10:19am |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1228 |
My favourite picture of what I got out my plenum chamber.
27th Aug 2022 10:30am |
We can’t really argue with Pete when he calls them dirty diesel devils
27th Aug 2022 10:37am |
That's what I am worrying about !! i feel a box of rubber gloves and a shed load of brake cleaner coming up 2012 Black 4.4 TDV8 1968 Mgb Gt |
27th Aug 2022 11:21am |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
The hoses are 70mm internal diameter. Buy whichever you fancy - lengths are around £10-15. 2015 Range Rover Autobiography 4.4 SDV8 |
27th Aug 2022 11:41am |
I'll be honest and if money was no object I'd just buy a new plenum chamber!!
27th Aug 2022 11:42am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
I'm tempted to go the new plenum route....are they expensive? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Aug 2022 2:32pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I bought a used one and cleaned it but it was a horrible job and wasn’t even that dirty. Still not got round to fitting it…… 2012 TDV8 Vogue (L322) |
27th Aug 2022 3:08pm |
Chrali Member Since: 13 Apr 2017 Location: Norwich Posts: 122 |
"I'm tempted to go the new plenum route....are they expensive?" They're about £500 quid for a genuine one. Luckily I didn't have to pay it. Encourage alternative fuels, use all the petrol!
28th Aug 2022 8:31pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 827 |
holy moly, does this ever get cleaned out by main dealers when doing a major service ?? what size is that tray, it looks like a lot of gunge there |
23rd Sep 2022 5:17pm |
It's a Chinese take away container. There was about half that much again. I was very concerned about the amount I got out but apparently it is quite 'normal' with EGR's and the like. |
23rd Sep 2022 6:06pm |
Mitch l_2000 Member Since: 03 Dec 2023 Location: Leicester Posts: 1 |
Just wondering if anyone knows on the right hand map sensor (looking into the bonet) should that be pulling in air in as in live data it's reading 0 where as the left is giving a measurement that turbo was replaced about a year ago only noticed it as trying to clean egr as keeps going in to restricted power due to egr temp sensor 118k tdv8 4.4 westminister |
3rd Dec 2023 6:37pm |
