Home > Maintenance & Mods (L322) > Sunroof does not open |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
Have you tried pressing the switch upwards, as in towards the sky to see if it tilts? |
5th Jun 2022 2:06pm |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 101 |
Try up for 20secs, forward for 20secs What doesn't kill you is just bidding it's time. |
5th Jun 2022 2:15pm |
Yes, holding the switch either upwards or forwards about 20 seconds should make the motor recalibrate the end stops next time it’s used. If not, you have a bit more investigation to do…..
5th Jun 2022 3:20pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
You could check 3 fuses,
Fuses all OK What doesn't kill you is just bidding it's time. |
5th Jun 2022 3:37pm |
