![]() | Home > Maintenance & Mods (L322) > Sunroof does not open |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1273 ![]() ![]() ![]() |
Have you tried pressing the switch upwards, as in towards the sky to see if it tilts? |
nemmi69 Member Since: 16 Jun 2015 Location: Peterborough Posts: 104 ![]() ![]() ![]() |
Try up for 20secs, forward for 20secs What doesn't kill you is just bidding it's time. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7866 ![]() ![]() ![]() |
Yes, holding the switch either upwards or forwards about 20 seconds should make the motor recalibrate the end stops next time it’s used. If not, you have a bit more investigation to do…..
You could check 3 fuses,
Fuses all OK What doesn't kill you is just bidding it's time. |
