Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2517 |
Presumably you've checked your PS fluid reservoir level. |
28th May 2022 12:14pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 683 |
Yes and I've just changed it for fresh cold climate fluid. |
28th May 2022 5:29pm |
Reidsr Member Since: 31 Dec 2021 Location: Aberdeen Posts: 10 |
Guys, i have just disconnected and removed my antiroll bar links at the front only and its made a difference! The car has a lot more stability going over slight bumps and feels a lot less harsh a long the road. What i noticed when letting the antiroll bar arm free the n/s moves free while the o/s is solid on the way up, engine was off and car was on level ground,Maybe this is normal? No lights on the dash showing. Its definitely made the small bumps more bearable/smoother. I will do the rear links when I'm back in two weeks time as i know it all goes through the same dynamic response block. |
29th May 2022 7:23pm |
Thinking about this some more today.
30th May 2022 3:56pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7827 |
I thought about that too… and I think that would make the car lift up and/or down…. As the pressure changed.
30th May 2022 4:28pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
I still maintain that for general ride harshness the tyres are the main decider in reducing 'crashiness' which is easily demonstrated by changing tyre pressures (or type or profile). Changing air spring height just changes the height and not the pressure and I'm sure I read it's not connected with the stability system as it would not react quickly enough. Very sophisticated active suspension systems in some high performance supercars use hydraulic systems to instantly vary both the spring and damper rates. Lastly the LR description says it changes according to driving style so who knows what that means and it may even go stiff with moderate accelerator or steering inputs if it senses the driver is in a 'sporty mood'...... 2012 TDV8 Vogue (L322) |
31st May 2022 9:49am |
I do completely agree with regards to tyres jaygee however mine is running correct sized 255 50 20 Pirelli scorpions with a date code of 2021 and around 6mm tread so should all be good and everything was in fact fine for the first 200 miles of my ownership until hitting that bad patch of road at 10-15mph.
31st May 2022 1:32pm |
255/50 R20 are what I'd consider to be 'low profile' for these cars. Mine came with the larger 255/55 R20 from the L405 which many consider to be an upgrade in comfort. Even a few PSI above the recommended pressure and the ride quality suffers.
31st May 2022 1:50pm |
Completely understand what you are saying Jaygee however in my case the car was fine previously and it was only driving over rough cobbled road at 10-15 mph that caused an immediate degradation in ride quality.
1st Jun 2022 1:09pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
My car was noticeable harsh today with no real cause as far as I recall.
7th Jun 2022 7:31pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
That is a very good point, I calibrated my dampers yesterday, I'll do the steering today. Christian.
8th Jun 2022 12:44pm |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Hi all,
13th Jun 2022 12:07am |
Hi Sam,
13th Jun 2022 6:00am |
Typical behaviour when a shock has lost some of its oil causing the oil to froth when worked then the air works its way back out when left to sit for enough time. Fully extending the shock forces the oil to the bottom when it can do its job for a little while.
13th Jun 2022 8:00am |
