Home > Maintenance & Mods (L322) > Restricted performance 4.4 tdv8 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7781 |
Welcome,
18th May 2022 2:46pm |
https://www.fullfatrr.com/forum/topic37268...over+valve
18th May 2022 2:53pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3762 |
Welcome to the forum , and the 4.4 tdV8 gang
18th May 2022 6:12pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4298 |
Defo look at CSOV first. There is a modified version.
18th May 2022 6:32pm |
Oakesy2001uk Member Since: 18 May 2022 Location: Cheshire Posts: 16 |
Great advice all - i’ll have a look today and let you know how i get on! |
19th May 2022 6:43am |
Its not the changeover valve, cant see a nut on top, just a stud so looks like the later design. I put oil on and hlgave it a wiggle anyway, but on test drive first time over 2500rpm it went into restricted again.
19th May 2022 10:15am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
The donut (plenum) has been know to split at the seams so give this a good look whilst you have it removed.
19th May 2022 10:34am |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
I'm leaning towards it being one or more of the rubber hoses running into the donut. It's the most common fault on these 4.4 TDV8's. Had the same problem as you have encountered, FF was fine at normal speeds / lower revs, but would 'Fault' as soon as I gave it a bit of right foot on the loud pedal. I found a minor split on one of the right hand hoses going into the Plenum on my FF and that was what was causing my fault.
19th May 2022 2:40pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3130 |
get a HIGH pressure smoke test done. It could be the inlet manifold. |
19th May 2022 5:06pm |
Hopefully theres a pic on here showing the hoses. I’ve almost got to donut off. Can’t see any obvious leakage at this stage |
23rd May 2022 12:01pm |
The 4 small ones on the donut itself…. Those ones?
23rd May 2022 12:56pm |
Apologies i was trying to show a pic of mine.
23rd May 2022 1:05pm |
They look like the original hoses that are prone to splitting.
23rd May 2022 1:48pm |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3178 |
Those appear to be the old style ones which were prone to splits. The newer ones pictured with the white lettering are the split proof ones. You can make your own much more cheaply from silicone reinforced tube. 2012 TDV8 Vogue (L322) |
