Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
The red curve is an MOT fail……
17th May 2022 11:24am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I am having an issue with my rears at the moment, though the difference is this throws a fault so the whole car just goes stiff like driving a sports car. My issue is the plug on my right rear keeps popping off!! i now have it cable tied in place. but I did take some live readings with Icarsoft V2.
17th May 2022 1:34pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
That makes sense for how I imagined it might work.
17th May 2022 6:03pm |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 |
It’s frustrating that you are able to get readings from your icarsoft, whereas the IIDTool is unable to. I did ask GAP, but only got a rather terse response about only showing what Land Rover supplies.
17th May 2022 6:43pm |
MarianaWestminster, now you’ve had a bit longer with the new strut, how are you finding it? Still happy with it?
17th May 2022 6:45pm |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 675 |
Hi ffrr lover,
17th May 2022 7:21pm |
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 |
Might be a couple of weeks now until I can get to it, on a mission next week to rescue a certain big green Cummins powered machine from the UK
17th May 2022 7:26pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4303 |
Site sponsor Advanced Factors sell BWI ones which I understand are OEM spec.
18th May 2022 7:17am |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
I went with LR genuine for the front. Wasn’t much in it when I looked 1995 4.6 v8, green/tan (long gone)
18th May 2022 7:19am |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 106 |
Hi all
18th May 2022 8:32am |
Yeah, it’s a bit subjective till we ride in another one…. Difficult to tell what’s “correct”.
18th May 2022 8:41am |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2486 |
I replaced mine's fronts after having already replaced the rears and noting that the front of the vehicle rode my 2km rutted dirt track driveway very harshly compared with the rear, feeling every little bump. With air-springs not having the return to centre characteristic of steel springs that causes bounce even on quite smooth surfaces, worn-out shocks can be less obvious. |
18th May 2022 10:58am |
So after reading the thread I thought I would try a bounce test,
18th May 2022 6:07pm |
I'm guessing you were bouncing the car at a standstill?
18th May 2022 6:10pm |
