![]() | Home > Technical (L322) > Help me out with the suspension on my 'famous' 4.4TDV8 L322! |
Ffrr-lover Member Since: 04 May 2021 Location: Lincolnshire Posts: 640 ![]() ![]() ![]() |
With the car off (last used about 3 hours earlier), I tried bouncing the car using the lowered rear tail. The car suspension is stiff and I appeared to get less than an inch of travel with my slight and slender ( |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
I know we don’t really know how it works… I’d hoped an expert might be on here….
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 707 ![]() ![]() |
Thanks for the informative post FFRR lover.
Just been out the car with SDD and I can confirm with the engine running no current is supplied to the dampers until the vehicle begins moving.
Nice one. No point in me trying that comparison then.
Mjdronfield,
Indeed. Would eliminate the “control system”.
Does it even respond to road undulations? IMO it’s just to control roll in corners and is not a ride comfort system. It can become a discomfort system when it fails though…. 2012 TDV8 Vogue (L322) |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2595 ![]() ![]() |
Reducing roll in corners is a secondary use of the shocks, with smoothing bumps as suspension compresses and extends their primary task. Have you noticed how the vehicle doesn't bounce a couple of times after hitting a bump, unlike non-CVDs? The valves are operated to provide a controlled rise and fall of the body.
Bilstein fronts are not as much of a bargain here than their rears. I can’t imagine there is an issue mixing brands front to back.
LandyManSam Member Since: 10 Jul 2019 Location: Wild West Ireland Posts: 51 ![]() ![]() ![]() |
Hi all... apologies for the long delay. I don't get as much time for forum reading and posting as I'd like!
Yeah….. seems to be looking like front struts for most parts. When mine hardened up, it was like flicking a switch… had new rears for MOT and that changed nothing.
Dampers remove the oscillations at the resonance frequency of the suspension to avoid loss of tyre contact. If your suspension ‘bounces’ ( cvd or not) the shocks are worn and need replacing. 2012 TDV8 Vogue (L322) |
I think Graeme means with 'normal' dampers, your suspension motion is a bit like the red curve, where it oscillates and overshoots the 'centre' position a couple of times before coming to a rest.
