![]() | Home > Technical (L322) > 4.4 TDV8 no start no crank |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 72 ![]() ![]() |
Thanks David. Would you test the compression on these engines via glow plugs hole, right? I saw they were located inside the V when doing the seals on the oil cooler. Certainly seemed easier than going through the injectors which look like a real pain to remove. I guess if the engine is not starting due to low compression, a safe assumption would be that it's the piston rings, and possibly valves (but less likely)... Last edited by PeterRRVogue on 6th May 2022 9:39pm. Edited 1 time in total |
SilverSpanner Member Since: 28 Jun 2017 Location: Hamilton, South Lanarkshire Posts: 17 ![]() ![]() ![]() |
Don’t rush to change anything else, you’ve already spent considerable cash so far, perhaps unnecessarily. Get it running before doing anything else. Even with low compression it should run. Are the high and low pressure fuel pumps running and delivering fuel? The fuel filter for this car is almost £60 although an inferior one can be fitted. Are you getting fuel through the filter to the engine? Diesel engines certainly rely on compression to ignite, but I don’t see all 8 cylinders low. Check the fuel pressure on the fuel rails. The ECM shuts the pumps down if the tank is very low on fuel. None of this of course explained the mega fuse blowing, and as others have said, the engine oil was in pretty poor condition. The cranking motor could have been defective and drawing too many amps if it had been persistently operated to try and get the engine to fire. Keep us up to date of progress. 2012, FFRR Westminster TDV8 - Orkney Grey
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1365 ![]() ![]() |
I'd be tempted to be feeding some easy start into it when someone is cranking it, I know it's not the best way (before anyone jumps up and down in rage) but would show if it does run when fuel is present |
So yesterday, I wanted to try and crank it again and I found myself pretty much at the begging again. Unable to even turn the ignition on (see video). Today I tried again and pretty much the same result, the only difference was that the ignition would stay on (instrument panel on) after the first press of the button, but when pressing the start button again to crank the engine, it would just die on me again, no crank. First though was that it must be the MEGA fuse again (even though I was pretty sure I didn't during the previous crank attempts) but I checked and indeed, it turned out that the fuse is still ok. I also searched for codes with the GAP IID tool and I only got one code " IPC- Instrument Pack - U0128-00 (2E) Lost communication with parking brake control module) which cleared out.
yes, the fuel is low (38 miles left according the computer) but I'm skeptical that this causing the ECU to shut down the pumps. Also I put it a new BRITPART fuel filter which got refilled with diesel (I checked) and I could hear at least one of the pumps running when the ignition on. I definitely need to test the rail pressure / injector leak test etc. but first I need to get to the bottom of the electrical problem! I wonder if I possibly could haver a faulty instrument cluster? The behaviour just doesn't make sense to me. Also I am a bit disappointed with the GAP IID tool, unless I'm missing something, It doesn't show any advanced live data to help to diagnose this issue (don't mean live engine data when the thing is running). |
Get a couple of gallons of fuel in and come back and tell us that its running |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 901 ![]() ![]() ![]() |
Was about to suggest the same thing on the basis of checking the obvious things first!! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
The IIDtool as supplied doesn't have an option set that is required to see all faults, with only 2 boxes checked rather than 3. IIRC the pending faults box has to also be checked.
Does the ignition stay on if you don't have your foot on the brake pedal? |
Will get some diesel in the morning on the way from a school run and report back. If this is caused by low fuel, I will eat my hat and shoes right there and then! |
Thanks for flagging this. I enabled the 'Pending' option, re-run the fault reading and no additional codes came up. |
It does today, but it didn't yesterday (when I took the video). |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
On our 4.4 if you try cranking it when the battery is flat everything goes off like that.
The 2 month old battery has been on a tricker charger pretty much since it arrived. I tested the voltage this morning and it’s showing 12.8v and my CTek charger reads it as fully charged so I believe the battery is fine. I also put in 10l of fresh diesel in the tank and tried my luck. Got in the car, pressed the start button (without my foot on the break pedal), the ignition came on, still with the “low battery warning”, pressed the break pedal, pushed the starter button for 2-3s and the screen went back to the “horizon” mode with low battery warning right in the middle of the screen. So I got my jump leads and connected a second (fully charged) battery to rule out the battery issue and exactly the same behaviour. So for some reason the ECU thinks the battery is low while it’s not… It seems that’s what is currently stopping the car from cranking.
