Home > Technical (L322) > 4.4 TDV8 no start no crank
Page 2 of 13 <123 ... 111213>
johnboyairey
PeterRRVogue wrote:
johnboyairey wrote:
of course, if you were to remove the oil suction cover for draining the engine sump, and with some tube, fitted, blow in... it should be sealed after a blow, and not pouring your 'puff' out of a hole in the block.... I just wonder if you have the typical starter motor wiring issue... AND a hydro locked engine, from the turbo, or water leak/wading calamity. I would be trying with thick cables direct to the starter, from another battery, with ignition on.... to see if it will indeed spin a little... and not crap itself every time you key the button.
Thanks Johnboyairey!
I will try today to spin the engine with a second battery with ignition on. Just to check that I'm on the same page with this, here is what I'll do: I connect the constant 12v from the Starter to the positive terminal on the second battery, Negative terminal from the second battery to the negative terminal on the main battery (or directly to the engine block); and then I try to start it by bridging the constant 12v on the starter with the solenoid terminal on the starter. I assume this is what mean?
Also I will try to blow air through the oil suction pipe and see if the block is air tight or not and report back.
you will be blowing through the oil, from the bottom... so it will be hard to blow.... (don't suck!!!!). or try and put mouth over oil fill hole, possibly difficult to do though.. to pressurise etc.... as for the wiring, thats what id do, but just run a fly lead from second battery to the small starter terminal.... it should engage the solenoid, and spin the motor, with decent amps, and you should know if anything is different than with the original battery.... jump cables tend to be hard to connect correctly to terminals, so have a few attempts. you could also watch the battery voltage on a meter, when cranking the original one, and see if it drops hugely... 12.6volts at rest and when cranking you want that to remain... not fall massively
remember, just because you charged ithe battery, for a long period, does not mean its charged.
Post #629167 19th Apr 2022 10:23pm
PeterRRVogue
Hi guys, so I managed to do as suggested and here are the results:
1) I disconnected the constant 12V from the starter motor, and applied a direct 12V from a second battery. Initially I had no spin but after several attempts, the starter started spinning the engine, albeit not very freely (see attached video)
https://www.youtube.com/shorts/6Ud9T3hns-I
Post #629200 20th Apr 2022 12:34pm
PeterRRVogue
I also connected a tightly fitted tube to the oil suction pipe (see foto) and tried to blow in. The bad news is that I could fairly easily blow the air in (hearing oil bubbling in the engine). I could not see any oil escaping from the side of the engine (the engine has 9.5l of fresh engine oil) but if I understand this correctly, I shouldn't be able to blow the air into the engine unless there is a hole in the block?
Post #629202 20th Apr 2022 12:39pm
GraemeS
Australia
The engine has a breather that vents to the inlet tract.
Your video sounds as though the battery doesn't have enough cranking amps.
Post #629207 20th Apr 2022 1:15pm
johnboyairey
well, it turns over! maybe you don't have high current passing through the connections, and its as sluggish as the video suggests. guess its still easy to reconnect the original cables, and try again, and maybe with a different battery, (the second battery?) and see if it cranks faster? i wouldn't worry about looking for a holed block, as that is a typical thing of a terminally ruined engine, (normally if a con-rod bearing starts to run dry, and start 'knocking' and then lets go from the crankshaft, it get hit by the crankshaft on the next revolution, and is smashed through the block... its still possible, but you might be seeing oil getting thrown out that hole by now, with the slow cranking... i would stick to getting good cleaned connections to the starter, and battery terminals, and seeing if it will crank faster. if you can get it cranking, but not 'firing' that can be a multitude of different things, but the way to prove it 'can fire up' is to spray some Easy Start (halfords) into the plenum, via the air filter pipe(s) pop one off, and give it 5 seconds or spray into the engine) -if you get a slight fire up, then you are missing fuel, ie fuel pressure.... and the easy start is firing up, and trying to start etc. it needs to be pinning over faster firstly though. keep the details coming! -can we get longer videos??
Post #629210 20th Apr 2022 1:25pm
PeterRRVogue
Thanks GraemeS! So that means that being able to blow air into the oil suction pipe doesn't mean that a piston punched a hole through the block..?
Also I tested the positive battery cable at the starter motor once again (just to be sure) and I definitely get no 12v there which means the cable has definitely a fault.
Could my issue by purely caused by a faulty alternator (dead shot) and battery cable or the hesitant engine spin also suggests a mechanical engine issue?
Post #629211 20th Apr 2022 1:26pm
PeterRRVogue
I guess before I reconnect the original cable, I first need to fix the main battery cable issue at the starter motor as currently there is no constant 12V going to the SM though the original cable. Also I suspect that the alternator might be faulty causing dead short as I keep getting 'low battery" warning despite that the fact that the main battery is brand new and constantly on a trickle charger. It doesn't seem like removing the alternator is an easy job just to test this theory though Rolling Eyes I will probably just order a new alternator and try to fix the main battery cable and then try to start the normal way and see if it spins! Sounds like a lot of work just to do a test, so if anyone has a suggestion on how to disconnect the alternator without going into all that effort, I'm all ears Smile
Also I will take more and longer videos to keep you guys posted!
Post #629215 20th Apr 2022 1:40pm
johnboyairey
its possible to buy thick battery cables online.. so you can make up a cable, and run it direct, (with caution near exhaust etc) and bridge to connection with a known good cable. seems strange its not passing power, and i mean, 'no 12v' as you say....lack of high amp current is one thing, but no 12volts is like fully disconnected..sounds like the mega-fuse????
Post #629216 20th Apr 2022 1:48pm
PeterRRVogue
I get what you saying, but that's exactly what I find very strange too! I tested and cleaned both MEGA fuses and they look fine. But will do more checks and come back!
Post #629218 20th Apr 2022 1:55pm
johnboyairey
there are some threads on here regarding the starter motor trigger wire, on the 4.4 tdv8... i have this issue, and changed starter motor twice now.... but yours has a slight different issue, in that the main cable is faulty, and not the trigger (thinner) cable. cables can go high resistance, through overheat, oxidation, even theives can reach under to cut cables to disconnect battery etc for alarms etc. im sure you will get your moment of bliss when the problem is revealed.... and you inform us its running!
Post #629226 20th Apr 2022 2:39pm
GraemeS
Australia
If you disconnect the mega-fuse, is there a huge spark when reconnecting it with the battery connected? I suspect not as you would have mentioned it but no huge spark indicates that the alternator isn't causing a dead short. Terminals are crimped onto cables which can work loose if the cables can move near the terminals which then become high resistance joints.
If you have jumper leads you could try connecting both leads in parallel from the battery positive to the starter terminal but that still won't be as good as a proper battery cable.
Post #629265 20th Apr 2022 10:10pm
JayGee
Sounds like a weak battery on that video. 2012 TDV8 Vogue (L322)
Post #629287 21st Apr 2022 9:50am
PeterRRVogue
Alright guys, so I made a breakthrough with the 'no power to the starter' issue. And I have to say that I feel like a proper moron now! Anyways, the whole time when it was referred to MEGA fuses, I always assumed that the only MEGA fuses there were, were the couple on the firewall behind the battery. However when I looked at the direction of the positive (red) battery cables, I realised the those two (250A) MEGA fuses at the back weren't powering the starter and I assume neither the alternator. So I had the light bulb moment Embarassed to open the black plastic box directly connected to the positive battery terminal and what did I find there...? Another MEGA fuse, and this time it was the 400A one! This one turned out to be a complete toast as I couldn't get any continuity on it at all. Now I wonder what would cause this MEGA fuse to blow? Could it be a dead short on the alternator as suggested by Baltic Blue? or something else? Anyways, a brand new DENSO alternator is already on the way so now I need to find and order a new 400A MEGA fuse.
Goes without saying that I feel like a proper fool for not figuring this one out sooner and I'm super grateful for all your incredibly helpful advice! I promise to keep you guys posted on my journey till the bitter end. I'm just praying that there will be no major mechanical issue with the engine as seeing all the buildup of oil sludge when taking off the top oil cooler / oil filter assembly didn't make me feel too hopeful. At the minimum, I wouldn't be surprised if the turbos wave good bye soon even if I did get the engine running after fixing this electrical issue..
Post #629296 21st Apr 2022 10:54am
dhallworth
I’ve been following this with interest. I don’t think I’ve ever seen or heard of one of those fuses blown.
Probably not what you want to hear but I wonder if your engine is tight which is what’s causing it to turn over slowly which in turn has put extra load on the starter and blown that fuse.
Shame it’s such an awkward job to get to the crank bolt.
Post #629298 21st Apr 2022 11:16am
Baltic Blue
So that’s what a 400A Megafuse looks like. Thumbs Up , we are all going to learn a lot from your pictures and work.
Thanks
Post #629299 21st Apr 2022 12:07pm
