![]() | Home > Technical (L322) > 4.4 TDV8 no start no crank |
PeterRRVogue Member Since: 22 Jan 2022 Location: Brackley Posts: 72 ![]() ![]() |
Hi all,
yes, I managed to rotate it back and forth within the range of motion I had to play with (from top) |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I wonder if assuming bottom end is free, that the pistons are hydro locked... Ie some fluid in the piston crowns, stopping the engine turning further....water/oil etc... is there a way to turn it, to locked position, and strapping the bar at that position, to see if it will come slightly released, and able to move on a little after a period of time. obviously, if the injectors were out, it would allow turning... but that can invite more problems. can also be a bent valve or two! |
Here is what happens when I try to start it. PS: The battery is fully charged despite the warning message
of course, if you were to remove the oil suction cover for draining the engine sump, and with some tube, fitted, blow in... it should be sealed after a blow, and not pouring your 'puff' out of a hole in the block.... I just wonder if you have the typical starter motor wiring issue... AND a hydro locked engine, from the turbo, or water leak/wading calamity. I would be trying with thick cables direct to the starter, from another battery, with ignition on.... to see if it will indeed spin a little... and not crap itself every time you key the button. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
No start no crank?
Thanks Johnboyairey! I will try today to spin the engine with a second battery with ignition on. Just to check that I'm on the same page with this, here is what I'll do: I connect the constant 12v from the Starter to the positive terminal on the second battery, Negative terminal from the second battery to the negative terminal on the main battery (or directly to the engine block); and then I try to start it by bridging the constant 12v on the starter with the solenoid terminal on the starter. I assume this is what mean? Also I will try to blow air through the oil suction pipe and see if the block is air tight or not and report back. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2633 ![]() ![]() |
As the alternator B+ cable is connected to the starter cable at the starter, I suggest that you disconnect the main power cable from the starter motor and use another cable to a battery to try the starter with the alternator disconnected in case the alternator is creating a dead short as they are prone to doing when they fail.
That's a good call! I will try that later on today |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3802 ![]() ![]() ![]() |
I think I am right , but others may be able to help more, in thinking that if the alternator diodes blow and it then puts a short directly on the battery feed it is possible that it will have blown the Mega fuse. (400 amp )
Thanks Mike, I checked, cleaned and tested the MEGA fuse's so they are not causing the problem. Do you mean that the alternator is unlikely the issue as it would have blown the MEGA fuse, otherwise? Last edited by PeterRRVogue on 19th Apr 2022 1:15pm. Edited 2 times in total |
I would still do as GraemeS suggests and separate the two cables , then apply 12v directly to the starter motor. to eliminate both the alternator and the starter motor solenoid.
The 220A alternator won't blow the 400A fuse. If the engine is running then the battery will be flattened within a couple of minutes but if not running then the short circuit will deprive the starter of adequate current to operate. |
