Home > General > What Did You Do In Your Full Fat Today
Page 350 of 378 <123 ... 349350351 ... 376377378>
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
Stripped and cleaned my front brakes yesterday. The pads and discs are fairly new and decent quality but I was getting a bit of steering wheel wobble when first applying the brakes at motorway speeds. Now with everything cleaned up and extensively greased, the brakes are back to what they should be.
I’ve now fitted discs and pads all round had to strip and service the same brakes within 12 months. I had a Volvo zc90 for 4 years and didn’t touch the brakes once!
Ah well, it makes up for it in other ways I suppose - the defender needed new backs last time it was MOTd, as well, the joys of the green oval,
Post #627638 3rd Apr 2022 8:51am
Baltic Blue
Flushed out the rear washer pipes and cleared the jets in the wiper arm.
It was the one way valve that was blocked last time, but the temporary one I fitted three years ago from a garden plant watering system is still working good.
I suspect that the screen wash from Eurocarparts is causing the problem by emulsifying in the tank.
I have refilled my tank with a much weaker solution now the worst of the winter frosts is behind us (hopefully)
Post #627639 3rd Apr 2022 9:32am
Gunning
England 2013 Range Rover Autobiography SDV8 Baltic Blue
 19 L405 4.4 AB + Disco3 pick up + 800BHP Rothmans 911
Previous RR:
ALOT
Post #627675 3rd Apr 2022 6:36pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Re-dyed and removed creases from the passenger seat and drivers seat. Cleaned all the leather throughout and then fed it using gliptone leather food.
BEFORE.
AFTER.
Post #628731 15th Apr 2022 5:24pm
Weegie
Had the aircon regassed. Wasn't before time! Had it done at KwikFit. Very pleased. Machine does a leak test before re-filling. They say if it doesn't work they won't charge. John
GAP iiD BT
Post #628785 16th Apr 2022 1:08pm
RutlandBoy
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
'Upgraded my HVAC so I can switch on my seats without using the screen
Here the thread if anyone is interested
https://www.fullfatrr.com/forum/topic63174.html L405 4.4 V8 Vogue SE Santorini Black
RRS L390 4.2 S/C Stornoway Grey
Classic Range Rover Overfinch 5.7 - their first prototype - under restoration
Late Range Rover P38
Range Rover 3.9 Classic Softdash
Range Rover Classic Overfinch 5.7 - Sadly gone
Disco 3 - Gone
Disco 2 - Gone
TD5 - Gone
Post #628824 16th Apr 2022 9:19pm
Essex2866
First long run
I took the FF for a drive from Essex to Grantham to look at our new house yesterday
She did really well and averaged 30 mpg (3.6 TDV8)
Cleaned all the bugs off this morning
Post #629015 18th Apr 2022 8:16pm
Huttopia
Full clean / wax / interior clean / leather clean and feed. Still need to sort the grille…
Post #629024 18th Apr 2022 8:55pm
dingg1
New front drop links and front control arms fitted, one ball joint on control arm had play and opposite side drop link had play, steering wobble at 70mph now sorted Thumbs Up
Not looking forward to doing the other control arms with the removable ball joint, looks a bit of a 'mare
Post #629887 27th Apr 2022 1:26pm
Golden age
United Kingdom 2019 Range Rover Autobiography TDV6 Santorini Black
Had a Ghost II fitted ....7th day of ownership .
Post #629937 27th Apr 2022 8:25pm
Bean19844
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Bought mine a blackvue dr900x ch2. Should be a barrel of laughs fitting this
Post #629951 27th Apr 2022 11:35pm
Spence
Good day out in the Perthshire hills.
 - L322 TDV8 4.4 Westminister
- BMW G01 X3
- BMW R1200 GSA
Gone but not forgotten
- Series III Lightweight (1977, Ex Saudi Military)
Post #630328 1st May 2022 8:42pm
Slow progress
Thought I’d check/change the rear wiper blade. Normally a 2min job……1hr later and 2 skinned knuckles we got there!
It only involved the use of a hammer, wd40 and a kebab skewer!
Before
Afterwards
For reference I’m not a complete numpty, but it had rusted on and the plastic tab to squeeze was brittle and snapped off! Ach! well it’s done now and all working 👍 L322 TD6 2003
Epsom Green- the dogs car which has worked it’s way into being the family car 😮
Post #630509 3rd May 2022 10:56am
Philclemo
Not today but last Friday. I drove my Westie up some ramps to check the new ball joint arms the selling dealer had fitted after it had an advisory on the MOT they had put on it.
Since I have had the vehicle there has been a loud 'dink' noise coming from either side of the front suspension, usually a low speed when parking. I did suspect that these arms perhaps hadn't been torqued up correctly. Well, my suspicions where well founded. They were no where near the torque they should have been. So I loosened them and then torqued them up to spec. Result - no more noise. Luckily, the arms hadn't suffered in any way as a result of their bad fitting - happy days! RR Westminster 2012 4.4 TDV8 Orkney Grey
LR Freelander 2 TD4e HSE Stornoway Grey - gone but not forgotten
Post #631083 9th May 2022 1:57pm
btiratsoo
United Kingdom 2009 Range Rover Vogue TDV8 Buckingham Blue
A trip to Kimmeridge Bay.
 Current vehicles:
1944 Fordson Standard
1982 Land Rover Series 3 88" petrol
1984 Ford 4610
2009 3.6 TDV8 Vogue
2017 CLS Shooting Brake
Post #631093 9th May 2022 4:50pm
