Home > Technical (L405) > front knuckle cracking |
Jon Byrne Member Since: 09 Apr 2022 Location: N Ireland Posts: 12 |
Vin ends 221992. |
11th Apr 2022 9:56am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1249 |
Does that mean it effects 32456 vehicles?
11th Apr 2022 2:46pm |
Report sent to DVSA. |
11th Apr 2022 8:40pm |
I have examined the failed hub carrier and have compared my customer’s failed part to some of the photographs provided on this forum.
21st Apr 2022 1:56pm |
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 |
Thanks Jon,
21st Apr 2022 2:54pm |
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 135 |
Just caught up with this thread - just checked mine and its under too! Phew!! Current Vogue SE 4.4 SDV8 Previous highlights Many Mini's! Audi S8 Audi A6 Avant (the petrol guzzling Bi-turbo) Subaru H6 3.0 Estate Peugeot 406 Coupe V6 Audi 80 Quattro Sport |
21st Apr 2022 3:56pm |
Absolutely Goddo, and it might help bring peace of mind to some owners of these premium market vehicles. I feel that JLR could implement this simple test when they bring these vehicles in to their workshops and address this potentially fatal manufacturing flaw professionally instead of trying to pretend the problem does not exist. For now you will all have to check it yourself. |
21st Apr 2022 7:44pm |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 |
Would corrosion not reduce the gap too? BMW i3 Electric Car
21st Apr 2022 8:16pm |
In my opinion, the fact that the corrosion build up is inside the clamping joint and forms a solid band of corrosion, I can’t see how this would cause the gap to close and cause the joint to fracture. However, if after the clamping joint breaks on one side, as has clearly been the case in some of the cases I have witnessed, the corrosion then builds up in the crack that has gone unnoticed, it’s possible that the build up of corrosion in the fracture could potentially close the gap. That being the case it is vital to check the width of the original gap.
21st Apr 2022 9:45pm |
seatosky Member Since: 12 Feb 2022 Location: Texas Posts: 7 |
Thanks Jon, this gives us something to look for. And seems to make sense as to why it only affects some vehicles. |
22nd Apr 2022 3:21am |
My only thoughts were if corrosion occurred on the two opposing faces i.e. where you're measuring the gap, as corrosion takes place the surface area becomes coated with oxide etc which would narrow the gap? (I'm asking not making a statement). I worked offshore as a pilot / technician of remotely operated vehicles. We had lots of corrosion issues and obviously lots of sacrificial anodes etc to protect things. When surfaces corroded spanners would no longer fit because they grown in size, quite dramatically at times. The corrosion was also really hard material, not easily removed with wire brush etc. One thing sure, if the gap is significant and my concerns are not relevant, this is a great find. I still think the authorities should be involved and a recall done, the potential of this failure is horrific. BMW i3 Electric Car 2012 Full Fat RR 4.4 TDV8 (now gone) 2006 VW Touareg 3.0 TDi V6 |
22nd Apr 2022 6:32am |
AJGalaxy2012. I edited this reply as I did not read your message properly on a first read. I based my assumption of over tightening based on the reduced width of the gap. But on reflection I feel I should withdraw any suggestion that over torquing the bolt would cause this. However, I’m certain that corrosion build up is significant and agree it is very much possible that the progressive build up of corrosion will close the gap in the joint. I have not yet witnessed an example of a failed clamping joint that showed a build up of corrosion within the original gap that caused the gap width to reduce. I don’t want to say it is not possible, but just that I have not seen it personally.
22nd Apr 2022 10:07am |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 130 |
Jon i was reading your message about the 9mm gap when the balljoint bolt being tightened to 60NM as i have had both front Knuckles replaced on my L405 due to failure and was having a look on Wiki and noticed if you follow Landrover instruction to replace the knuckle it instructs the top arm balljoint bolt to be tightened to 60NM but if you look at the land Rover instructions to just replace the top arm it tells you to tighten the balljoint bolt to 70nm which is quite a difference. |
22nd Apr 2022 12:51pm |
Sorry that should have been .9mm Gap |
22nd Apr 2022 12:52pm |
