![]() | Home > My Range Rover > Cold Turkey over, think I've found my next one! |
stevepen Member Since: 03 Feb 2017 Location: Cheshire Posts: 64 ![]() ![]() ![]() |
Brilliant Guide. Just done mine at weekend. I changed the O rings a few months ago but still got the oil smell now and again. Gaskets done now so hope it's solved it. The old ones were very flat and it was a good opportunity to clean out all the crud from the intake manifold etc 2011 Vogue SE TDV8 |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
I found mine still smelt for quite a while after I did the change, I think the oil only burns of certain places when it is really hot or long run. Been fine for the last year or more but took months before it cleared initially.
Yes, same here. Done a couple of weeks ago and still had a feint oil smell for a few days. Was worried I'd not put something back properly. Nothing now and when someone is in the car with me I don't have to blame the car in front |
Pysta Member Since: 05 Sep 2021 Location: Bra Posts: 24 ![]() ![]() ![]() |
Finding myself in the same situation as most of you here, I prepared the tools, consumables and extra spare time to get the job done on a nice Saturday morning. The disassembly was going pretty smooth, took me something around 2 cups and an hour until I got the cooler assy out ... just to find out that some F% |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 779 ![]() ![]() ![]() |
Delivery arrived from Rob at Duckworths today and it's worth noting that the oil cooler gaskets have new part numbers, signifying an update / change to the original parts.
paul530a Member Since: 06 Feb 2022 Location: Harpenden Posts: 2 ![]() ![]() ![]() |
JMC, do you have a part number for the large air hose and connectors shown in your photo. I'm just about to start the whole process on my 2011 V8. |
mezo Member Since: 13 Mar 2022 Location: Milton Keynes Posts: 22 ![]() ![]() ![]() |
Great guide - i ordered the o-ring for the coolant hose, but elected not to replace it as it seemed ok - may live to regret that... |
I've just completed the fix. It would have been extremely difficult without this great guide. Some of the bolts were tricky to find without reference to the photos. I got the new seals part numbers are LR113003 & LR113004 and replaced the orings in the oil feeder and the water pipe.
So my original "new to me car thread" has in reality turned into the oil cooler replacement thread |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3179 ![]() ![]() ![]() |
It's nice to see one so solid in the cills after recent pictures!
Not difficult to remove but fiddly. If you have sidesteps these need to come off first which is easiest done on a ramp.
MC-RR Member Since: 26 Jan 2022 Location: Monte Carlo Posts: 25 ![]() ![]() ![]() |
What a superb walk through mm289 A pleasure to read and view.
Jon G Member Since: 02 Dec 2016 Location: Leicester Posts: 120 ![]() ![]() ![]() |
Just done the O Rings on mine yesterday.
nambFFRR Member Since: 07 Aug 2018 Location: United Kingdom Posts: 197 ![]() ![]() ![]() |
Hi
