![]() | Home > My Range Rover > Cold Turkey over, think I've found my next one! |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
3 months and 4000 miles in and the FF has been faultless, really happy with how it goes. Bit thirstier than had hope (26mpg average) but it isn't half rapid when it needs to be |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
While you’ve got it off, replace the 4 short manifold hoses onto the plenum. These are renowned for failing at some point and are about £100 for a set. |
Moving on to what we came here to do |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Fantastic guide! |
As NMJ says, try to avoid water contamination into the oil, I let the water drain out fully from the connections before removing the cooler then used a suction tube to suck out all the remaining oil and water from the mounting plate.
Woofster Member Since: 12 Jul 2018 Location: Toronto Posts: 121 ![]() ![]() |
Wow, that is some great documentation! 2010 RR SC
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 ![]() ![]() ![]() |
Good work Paul.
Thanks guys, hopefully contributes to the overall usefulness of this great site |
plumajp Member Since: 18 Jul 2013 Location: bridgend south wales Posts: 73 ![]() ![]() ![]() |
Does anyone know the torque settings for the bolts around the oil cooler. |
Apologies just read the post 3 up and saw 10nm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
Stan - is this in the wiki? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
yes it is Rob... ... - .- -.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1466 ![]() ![]() ![]() |
Thats a cracking looking car that is factory and thats the best way. Glad you got your issues sorted. |
Swapped the 2 oil cooler seals and oil pipe O rings on mine yesterday.
