Home > My Range Rover > Cold Turkey over, think I've found my next one!
Page 5 of 6 <123456>
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
If you look at the picture after the one you have quoted in the original post it shows where you need to insert a flat blade screwdriver. Its a pain to get at but needs to come from the end the cables come out of from memory and pushes in a plastic lug to allow the connector to slip off.
HTH
Paul. 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #634550 13th Jun 2022 8:04pm
Harlequin
United Kingdom 2007 Range Rover Vogue SE TDV8 Buckingham Blue
Sent a pm
Post #635027 19th Jun 2022 9:53pm
nambFFRR
United Kingdom 2016 Range Rover Autobiography SDV8 Corris Grey
HTH
Paul.
Sorted👍 I’m just a bit thick on electrical connectors for some reason!!??
A couple of observations while I’ve been doing the oil cooler swap
Three of the bolts that hold the oil cooler assembly down were soake in oil so that gasket was beginning to leak
But it’s clear now, the main culprit was the rear o rings on the oil pipe
Post #635512 26th Jun 2022 5:13pm
Steve200TDi
Thank you for the excellent how to guide!
I did this job a couple of months ago after order the two genuine Land Rover gaskets and a couple of 0-rings for the rear oil feed pipe. It took me a day from start to finish and I an now (and still) leak free. I even managed to break the coolant pipe you said to be careful of......and I was careful!! It's just very brittle!
Regards
Steve
Post #649357 28th Nov 2022 3:49pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Unnecessary quote removed
This is an excellent post, great step by step guide. Followed it earlier this week to change hoses . Thank you for taking time to post. Much appreciated Cheers
James
Post #664412 18th May 2023 12:46pm
TomC-RRV8
Does anyone know of a good supplier for the part that is bound to break when I do this job the intercooler pipe with the coolent feed pipes? See attached pic.
 Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
2004 Discovery Landmark 2.5D
2003 Freelander TD4 SE
Post #674332 26th Sep 2023 7:35pm
JayGee
It won't break unless you are very ham fisted with removing it. Main issue is the seal to the TB which can be improved using large O rings. 2012 TDV8 Vogue (L322)
Post #674335 26th Sep 2023 8:43pm
TomC-RRV8
Well, managed to do the whole oil cooler swap and no matter how gentel I was still managed to snap the connector trying to remove the pipe which had gone rock solid on it, now waiting for new part tomorrow to hopefully finish the job!!!
Great guide on how to was invaluable in completing the job, the amount of gunk in the intake was unbelievable!!! Current
2011 4.4TDV8 VSE
1972 MGBGT
Gone
Post #676141 22nd Oct 2023 4:21pm
Fla
Ireland 2012 Range Rover Westminster 4.4 V8 Zambezi Silver
Hi all
Im looking at doing this fix too as I have a 2012 4.4. my question is, I have posted pics here of my issue:
https://www.fullfatrr.com/forum/post679350.html#679350
I have ordered the o rings and now I need to decide do I order:
Oil cooler gaskets
replacement oil cooler
or
Replacement oil cooler and filter housing
I have a lot of oil crud and wet oil all around the filter housing and the cooler so Im thinking just replace the lot and be done with it. What do you think?
Im thinking while I await parts I should clean as much oil residue as possible and at least that might guide me to what is leaking the most. Current yokes
2012 4.4 TDV8 Westminster
Subaru Sambar Pickup Tipper
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #679491 4th Dec 2023 11:19pm
JayGee
Once you have gone to the effort of removing the plenum donut etc to get at it then you may as well replace the whole lot for peace of mind. The filter and cooler at one single item BTW. 2012 TDV8 Vogue (L322)
Post #679511 5th Dec 2023 10:24am
Fla
Hi Jaydee
I was thinking the same myself. I see you can buy the cooler or the cooler and filter housing but I'm thinking with all the sand, crud and gunk in there Ill be all day cleaning it so Im better off spending the extra 100 quid now and I know Ive new gaskets and units all the way through.
At least its a job you can do at home.. The walk through that is done here is so valuable, fairplay to everyone documenting their fixes Current yokes
2006 Disco 3
Scoobie GT wagon
Mx5 G Ltd
TT S Line
Pajero JDM Exceed
Post #679513 5th Dec 2023 10:30am
Mfcetin
Germany 2011 Range Rover Vogue SE TDV8 Alaska White
I just started with taking out the plenum but I got stuck already at the beginning.
Two of those 4 Studs in the front of the plenum are siezed or previous idiot overtightened it.
one on the right side was missing, the second came undone with hand but two on the left are siezed.
Head of one is kind of rusty and does not fit to femal torx 5 and the other one is bending as soon as I put some torque on it.
Any ideas how to take them out? I really wanted to fix this oil leak before going on my 1800 km trip
I will try the 2 nuts method, lets see :/
 2011 Vogue SE 4.4 TDV8
Post #692010 6th May 2024 12:34pm
Ramblin Man
England 2012 Range Rover Vogue 4.4 V8 Buckingham Blue
If you’ve not tried already get some penetrating oil on and leave for a couple of hours. Here’s what I have used in the past:
https://www.plusgas.co.uk/en-gb/products TDV8 4.4 2012
Post #692025 6th May 2024 5:21pm
Richie N
United Kingdom 2013 Range Rover Vogue SE SDV8 Baltic Blue
Is that the plate across the front that the intake sits on? I couldn’t Censored those either. I left the plate in place and there are 3 or 4 bolts underneath it holding the intake - I removed those instead.
Good luck..
Post #692029 6th May 2024 8:49pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
If you have stud extractors, these work well on these in an impact wrench to pull them out.
Post #692031 6th May 2024 9:46pm
