![]() | Home > Technical (L405) > Car lifts / ramps |
Thinking about getting jacking car ramps/ lift for the L405 and also for occasional DIY work on lighter cars.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1261 ![]() ![]() |
I agree with t5pete, 3T minimum, also better you also have something that locates in the recommended lifting points
Thanks for the replies.
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 372 ![]() ![]() ![]() |
Have you seen attached?
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 462 ![]() ![]() ![]() |
I have one of these V8 Bob points out, its a fabulous piece of equipment that lifts my SDV8 l405 no problem, its also portable so if you have a garage to store it you can roll it out onto the drive to work on the FF. Perfect for all sorts of work. Cost me 1500 quid but worth its weight in gold.
diesel Dave
Hi Kot, I use steel box section to give extra strength across the ramp. It does lift the car without them but end pieces flex and I want to be sure I’m 100% safe under there. Other cars are different and fit on the main part of the platform, L322 would for example as you could use the chassis as a limiting point, but the 405 does hang over, hence the mods, works well though.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
I have one of these and its the dogs...No issues or flexing.
Just to add, the extension pieces do line up with the jacking points unfortunately due to their location on the 405, although they’re not in any way flimsy, my thoughts were they’re hinged so I use the extra strength for peace of mind. If you have electric side steps it does help as the jacking points are more inboard but I still go with spreading the weight where possible. As ajac8 says they come with wheels and moving handles and an assortment of rubber blocks ![]() |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 601 ![]() ![]() ![]() |
Depending on your garage height, you may be better off with a 2 or 4 post lift. I put in a four post in 2008 mainly to use to double up parking, but its proven much more valuable over the years to allow me to mess with the cars in comfort and without danger. Mine was from InternBV in Holland, but the same design is widely available from others - usually a couple at the classic shows like at the NEC. Back then price was about £1500 but I think they're nearer £2500 now.
RiverBlanche Member Since: 20 Apr 2021 Location: Retford'ish Posts: 97 ![]() ![]() |
Hi,
Great replies, thank you… would like a 2 or 4 post lift of course but don’t think would use it enough and don’t think our garage roof height is enough for one of those (on the cars yes but not the RR)… excellent big long and wide double garage but not the tallest ceiling height…. think a scissor lift or those ramps that you drive on to and hydraulic jack up might be the way to go… thoughts thoughts thoughts |
Ryan, go for a 4T 2 poster. £1500 will buy you a new unit from eBay and for another £100 or so most companies will come and install it too!
Wish I had the room for a two poster in the garage, SWMBO wont let me have one on the drive |
