Home > Technical (L405) > Car lifts / ramps
pld118
Car lifts / ramps
Thinking about getting jacking car ramps/ lift for the L405 and also for occasional DIY work on lighter cars.
The handbook shows the vehicle weight of the L405 3.0 TDv6 is 2160kg and for the 4.4 TDV8 it’s 2360kg.
Do we think these lifts would be okay for those weight L405 - presuming this tilting lift isn’t bearing the full weight of the vehicle, ie either the front or back wheels will be bearing a fair amount of the weight when the car is tilted?
Thanks
https://cjautosheywood.co.uk/product/3in1-...on-cl01-2/
Post #624163 19th Feb 2022 2:01pm
t5pete
No I wouldn’t risk my life using one of them for the Range Rover ide buy one with a min rating of 3t regardless if it’s only to lift the front or the rear.
If it’s only for light mechanical work and not to be raised too high just buy a good high lift jack and tall heavy duty axle stands
Post #624185 19th Feb 2022 6:30pm
Kot
Re: Car lifts / ramps
I agree with t5pete, 3T minimum, also better you also have something that locates in the recommended lifting points
https://cjautosheywood.co.uk/product/2-pos...ift-cl07h/ even then I would want something else supporting the vehicle just in case! 2018 SE SDV8 4.4 Byron Blue
Post #624186 19th Feb 2022 6:48pm
pld118
Thanks for the replies.
I’d always use axle stands anyway so hoped that 2T tilter (only to be used with the RR with the front or rear wheels grounded) would be safe if the weight of the TDV6 is only 2160…
The 2 post thing would be too cumbersome and permanent a fixture for what I’d want.
Post #624195 19th Feb 2022 8:39pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Have you seen attached?
https://www.garageequipment.co.uk/Vehicle-...-Lift-with 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #624199 19th Feb 2022 9:17pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
I have one of these V8 Bob points out, its a fabulous piece of equipment that lifts my SDV8 l405 no problem, its also portable so if you have a garage to store it you can roll it out onto the drive to work on the FF. Perfect for all sorts of work. Cost me 1500 quid but worth its weight in gold.
Post #624243 20th Feb 2022 2:23pm
Kot
diesel Dave
It looks great and being mobile you could use them outside in nice weather, but a few questions
What's that black block running along the length off the ramp 3 x 3 timber? steel?
Do the hinged yellow extension pieces line up with the jacking points? would be worried that the extension pieces are hinged and, are they flimsy, just where you want them to be at their strongest at the jacking point?
Do you have close up pics of that jacking point area. 2018 SE SDV8 4.4 Byron Blue
Post #624247 20th Feb 2022 2:45pm
diesel Dave
Hi Kot, I use steel box section to give extra strength across the ramp. It does lift the car without them but end pieces flex and I want to be sure I’m 100% safe under there. Other cars are different and fit on the main part of the platform, L322 would for example as you could use the chassis as a limiting point, but the 405 does hang over, hence the mods, works well though.
Post #624248 20th Feb 2022 2:55pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
I have one of these and its the dogs...No issues or flexing.
https://strongmanlifts.co.uk/product/clifton-scissor-lift/
Very heavy but comes with jacking wheels and detachable handle etc. Also comes with a range of rubber support blocks. You just have to Mae sure the 405 is dead centre.
I still use axle stands under the ads and a bit of peace of mind.
Worth its weight in gold.
Had it a couple of years now I think is was about £1800.00 inc vat and delivery.
 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #624250 20th Feb 2022 3:06pm
diesel Dave
Kot wrote:
diesel Dave
Just to add, the extension pieces do line up with the jacking points unfortunately due to their location on the 405, although they’re not in any way flimsy, my thoughts were they’re hinged so I use the extra strength for peace of mind. If you have electric side steps it does help as the jacking points are more inboard but I still go with spreading the weight where possible.
As ajac8 says they come with wheels and moving handles and an assortment of rubber blocks Thumbs Up
Post #624258 20th Feb 2022 6:36pm
Depending on your garage height, you may be better off with a 2 or 4 post lift. I put in a four post in 2008 mainly to use to double up parking, but its proven much more valuable over the years to allow me to mess with the cars in comfort and without danger. Mine was from InternBV in Holland, but the same design is widely available from others - usually a couple at the classic shows like at the NEC. Back then price was about £1500 but I think they're nearer £2500 now.
 Mike - MPx
Post #624275 20th Feb 2022 9:03pm
RiverBlanche
Hi,
wish I had not had a look at this thread Sad its a long time until I can let swmbo know what I now want for Xmas Laughing
OP you have to be happy and safe with what you want to do and only you can decide that from how you plan to work on your car, but also the wheels are not rated for 3000kg each Exclamation
Post #624280 20th Feb 2022 9:27pm
pld118
Great replies, thank you… would like a 2 or 4 post lift of course but don’t think would use it enough and don’t think our garage roof height is enough for one of those (on the cars yes but not the RR)… excellent big long and wide double garage but not the tallest ceiling height…. think a scissor lift or those ramps that you drive on to and hydraulic jack up might be the way to go… thoughts thoughts thoughts Thumbs Up
Post #624284 20th Feb 2022 10:48pm
Ryan, go for a 4T 2 poster. £1500 will buy you a new unit from eBay and for another £100 or so most companies will come and install it too!
It might only lift your RR half way up (garage height) but at least the car will be 100% safe on it. When not in use you simply park between the two posts anyway! Easy peasey… 👍
Post #624288 20th Feb 2022 11:30pm
diesel Dave
Wish I had the room for a two poster in the garage, SWMBO wont let me have one on the drive Big Cry
Post #624291 20th Feb 2022 11:51pm
