![]() | Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3181 ![]() ![]() ![]() |
Is it the aluminium square that's on the spigots that you can't remove?
xjsracer44 Member Since: 30 Nov 2010 Location: Hertfordshire Posts: 274 ![]() ![]() ![]() |
Thanks, it is the aluminium square that won’t come off the spigot as it’s stuck on after 15 years. I will see if I can get hold of a puller, which should hopefully do the trick as I’m nervous of using force so near the windscreen |
Today marks 12 months to the day since the SC turned up on the trailer.
I set off for Tesco tonight in the SC and had some strange errors in the car. The car warmed up no problem but the heater didn't get warm, it was lethargic to do anything. I checked the coolant level before leaving Tesco and that was fine and when we got back into the car the heater was belting out hot air but the temperature gauge wasn't moving.
Been looking into the reason I have a misfire this evening and decided I’d make my own smoke tester out of an empty paint tin and some rubber hose.
Firstly, thanks go out to Diesel Dave who advised me how the front diff is removed once it's been unbolted |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 ![]() ![]() |
Weren’t they grey with black letters? |
I looked back through the brochures for the early cars and am fairly certain they were black with white writing.
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 ![]() ![]() ![]() |
Hello David, From the factory, the grey one (2007 MY) had grey calipers with black "Brembo" and the black one (2006 MY) has glosss black with white "Brembo" on. Hope that helps. ![]() 2006 L322 4.2 V8 SC Java Black |
You are indeed correct |
Everything is now changed and we’re ready to start reassembly. It’s taken forever as the air over hydraulic pump on our press decided it had had enough and packed in so I had to wait 10 days to get the parts to rebuild the press. Thankfully that was a lot cheaper then a new 30 ton press was going to be!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
Nice work David.
Good point. I'd forgotten about that. Will also make getting the pads out of the calipers easier.
Bit more progress today. New diff fitted and bolted in place.
