Home > My Range Rover > Back with another Supercharged |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3059 |
Is it the aluminium square that's on the spigots that you can't remove?
22nd Dec 2021 12:11pm |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 |
Thanks, it is the aluminium square that won’t come off the spigot as it’s stuck on after 15 years. I will see if I can get hold of a puller, which should hopefully do the trick as I’m nervous of using force so near the windscreen |
23rd Dec 2021 9:27am |
Today marks 12 months to the day since the SC turned up on the trailer.
3rd Jan 2022 8:50pm |
I set off for Tesco tonight in the SC and had some strange errors in the car. The car warmed up no problem but the heater didn't get warm, it was lethargic to do anything. I checked the coolant level before leaving Tesco and that was fine and when we got back into the car the heater was belting out hot air but the temperature gauge wasn't moving.
7th Jan 2022 1:03am |
Been looking into the reason I have a misfire this evening and decided I’d make my own smoke tester out of an empty paint tin and some rubber hose.
12th Feb 2022 10:04pm |
Firstly, thanks go out to Diesel Dave who advised me how the front diff is removed once it's been unbolted
13th Feb 2022 9:45pm |
322BLL Member Since: 18 Apr 2019 Location: Estonia Posts: 73 |
Weren’t they grey with black letters? |
19th Feb 2022 9:23am |
I looked back through the brochures for the early cars and am fairly certain they were black with white writing.
19th Feb 2022 11:55am |
strongstuff Member Since: 26 Jun 2019 Location: North Wales Posts: 44 |
Hello David, From the factory, the grey one (2007 MY) had grey calipers with black "Brembo" and the black one (2006 MY) has glosss black with white "Brembo" on. Hope that helps. 2008 L322 4.2 V8 SC Stornoway Grey 2006 L322 4.2 V8 SC Java Black |
19th Feb 2022 12:25pm |
You are indeed correct
19th Feb 2022 10:31pm |
Everything is now changed and we’re ready to start reassembly. It’s taken forever as the air over hydraulic pump on our press decided it had had enough and packed in so I had to wait 10 days to get the parts to rebuild the press. Thankfully that was a lot cheaper then a new 30 ton press was going to be!
3rd Mar 2022 8:43pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1199 |
Nice work David.
4th Mar 2022 2:06am |
Good point. I'd forgotten about that. Will also make getting the pads out of the calipers easier.
4th Mar 2022 11:50am |
Bit more progress today. New diff fitted and bolted in place.
5th Mar 2022 8:51pm |
