Home > Technical (L322) > Transfer Box oil leak |
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 |
Another day, another problem
27th Apr 2011 6:11pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
sorry to hear that justin, hope the repair goes well. ... - .- -.
27th Apr 2011 7:06pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
My transfer box started leaking a short while ago, I removed the breather and blew it through with an airline. So far no more leaks, hoping it was just an obstructon in the breather pipe. Only time will tell...... |
27th Apr 2011 7:11pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Did this solve it completely? |
24th Jan 2014 3:54pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
Mine was leaking from the seal between the two halves.(it splits in two) been done twice now. It is a 4-5 hour job apparently.
24th Jan 2014 8:23pm |
Yes, I think it is leaking from the split. If you've had it done twice its obviously a common fault! Did hunters in derby do it? |
25th Jan 2014 3:58am |
Yes, not a cheap job to do at the md though, the did it the first time under warranty, the second time the knocked me some cash off as it had only been done 18 months earlier. Its only a silicone seal so no parts are needed. There is nothing that can't be fixed with a hammer😜😜
25th Jan 2014 8:51am |
No gasket? Just silicon??
25th Jan 2014 9:15am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
Just the transfer box, then it needs
25th Jan 2014 10:20am |
Can't believe there isn't a gasket???
25th Jan 2014 11:56am |
Anyone done this? Its looks a straightforward job.... |
25th Jan 2014 1:38pm |
25th Jan 2014 1:46pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 963 |
I stripped a DD295 down here : http://www.fullfatrr.com/forum/topic12404.html in case anyone was wondering what the parts look like.
25th Jan 2014 2:42pm |
Excellent and interesting write up. Is it much trouble to just split the casing and apply some new silicone or do I have to take all the ancillary bits off first?
25th Jan 2014 3:34pm |
