Home > Technical (L322) > Transfer Box oil leak
Page 1 of 3 123>
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Another day, another problem Sad
My FF has started leaking oil on the drive, so I've run it back into the dealer and they have diagnosed the leak as a faulty oil seal on the transfer box. Evidently it's a 5 hour job to fix, so I can only assume it's a transfer box and possibly gearbox out time. Thankfully the approved used LR warranty have authorised the repair so it won't hurt the bank account.
Whilst they have the car in pieces, is there any preventative maintenance in that area, that I should get them to do at the same time?
Thanks
Justin
Gone - Range Rover Supercharged 2006
Post #61727 27th Apr 2011 6:11pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Been there in January-February only it was a diff oil seal not TF box so YMMV (I hope so!)
Potential horror story (at least for the warranty company!)
Oil seal on diff (facing TF box) involved stripping thee exhaust and so on,
The bleed screw was corroded in place, warranty engineer called out to approve new diff: approved!
re-fitting they snapped a manifold bolt which needed a 'special tool' (I offered to loan them my Snap-On extractor Rolling Eyes )
Then diagnosed a vibration; Engineer called to approve two new drive shafts: Approved!
Total parts bill £1150 (plus a brand new windscreen because part of the heater wasn't clearing)
Lovely stuff!
I hope the TF box is much easier!
Good luck! Thumbs Up
Post #61729 27th Apr 2011 6:34pm
sorry to hear that justin, hope the repair goes well. Thumbs Up ... - .- -.
Post #61730 27th Apr 2011 7:06pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
My transfer box started leaking a short while ago, I removed the breather and blew it through with an airline. So far no more leaks, hoping it was just an obstructon in the breather pipe. Only time will tell......
Post #61731 27th Apr 2011 7:11pm
wealy
Did this solve it completely?
Post #236845 24th Jan 2014 3:54pm
Mine was leaking from the seal between the two halves.(it splits in two) been done twice now. It is a 4-5 hour job apparently.
If it's either the input or output seal then the box still comes out and gets split to replace them iirc. There is nothing that can't be fixed with a hammer😜😜
Post #236913 24th Jan 2014 8:23pm
wealy
Yes, I think it is leaking from the split. If you've had it done twice its obviously a common fault! Did hunters in derby do it?
Post #236979 25th Jan 2014 3:58am
Yes, not a cheap job to do at the md though, the did it the first time under warranty, the second time the knocked me some cash off as it had only been done 18 months earlier. Its only a silicone seal so no parts are needed. There is nothing that can't be fixed with a hammer😜😜
Post #236992 25th Jan 2014 8:51am
wealy
No gasket? Just silicon?? Shocked
Do you have to take the gearbox out as well as the transfer box or just the transfer box?
Post #236998 25th Jan 2014 9:15am
T24RES
Just the transfer box, then it needs
Splitting to re seal.
Post #237004 25th Jan 2014 10:20am
wealy
Can't believe there isn't a gasket???
Confused
Post #237019 25th Jan 2014 11:56am
wealy
Anyone done this? Its looks a straightforward job....
Post #237037 25th Jan 2014 1:38pm
wealy
is this the solit line that leaks?
Post #237040 25th Jan 2014 1:46pm
RRPhil
I stripped a DD295 down here : http://www.fullfatrr.com/forum/topic12404.html in case anyone was wondering what the parts look like.
Phil
Post #237056 25th Jan 2014 2:42pm
wealy
Excellent and interesting write up. Is it much trouble to just split the casing and apply some new silicone or do I have to take all the ancillary bits off first?
Is it much of a job to get out?
Post #237067 25th Jan 2014 3:34pm
Page 1 of 3 123>
