Home > Technical (L322) > High beam assist
JamesDarby
United Kingdom 2011 Range Rover Autobiography TDV8 Buckingham Blue
High beam assist
Is high beam assist standard
On my car when on auto. The lights switch on but you just get the green side light on the dash, or the blue main beam. There is no green dipped.
The afs works on dipped. I don’t see any option to turn high beam assist on either.
Is this a fault or an option I don’t have.
Thanks
James 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #614898 5th Dec 2021 5:22pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
It came with the vision pack on the autobiography. For it to work you need to switch on your full beams. You then will see the great symbol with auto on the digital dash at the top right.
Post #614905 5th Dec 2021 6:07pm
JamesDarby
Thanks. That’s why it doesn’t work then as I haven’t got that option.
I wasn’t sure as it’s my first RR and first drive in the dark 2011 Range Rover Autobiography TDV8 Buckingham Blue
Post #614921 5th Dec 2021 8:31pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Can it be configured ? onto no6 Range Rover
Everyone needs a hobby
Post #615558 9th Dec 2021 8:10pm
Bl4ckD0g
Yup, if you have it on the car. Mine was working, but after playing with the CCF configuration I've managed to disable it Big Cry Rolling with laughter Still got to find the time to have another play and re-enable it...
Post #615567 9th Dec 2021 8:43pm
Sonearly
Retro fitted mine, operation seems different to what is stated previously. I just need to turn to auto on the switch and do not need to select full beam. The “auto” above the Green Headlamp symbol comes on when the ambient light switches on the lights. As side observation when configuring the files I was advised to set to North American. For some reason it appears to be more sensitive than on my previous L322.
Post #615591 9th Dec 2021 11:25pm
Bl4ckD0g
Interesting. Perhaps it’s different in that setting. But I’ll try it out.
Post #615598 10th Dec 2021 12:06am
Yes as stated above but you will obviously need to change the rearview mirror to the one with the camera on the underside... You will also need the plastic surrounds as they are different on the camera'd mirror Thumbs Up
Post #615606 10th Dec 2021 1:15am
BlackStang5point0
United Kingdom 2012 Range Rover Westminster TDV8 Baltic Blue
That's how mine works just leave lights on auto and the high beam comes on automatically.
Post #615618 10th Dec 2021 9:03am
dhallworth
No need to touch anything to make it work on our 2012 either. However, it always seems slow to respond. When a car is coming towards you they can often end up flashing at you before it's dimmed so I more often then not end up dimming the lights manually.
If you're on a straight bit of road it's great but it's almost like the camera field of view is to narrow.
It's much better on the L405's I've driven though. The L322 was the first RR to have it so it's presumably been improved upon over the years.
2007 Range Rover Supercharged in Java Black with Ivory Leather
Post #615679 10th Dec 2021 1:52pm
misfire84
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
I Agree the high beam assist is too slow to stop the oncoming driver flashing you , l322 2012 2012 Black 4.4 TDV8
1968 Mgb Gt
Post #615681 10th Dec 2021 2:00pm
Sonearly
I had read that the system needs to be calibrated to work correctly, this should be during the original build but conditions may not be the best in the factory. Apparently it is self calibrating when first powered, when installing mine I took it for a drive as soon as it was configured, initially it did not seem to work but after a short drive it began to work, admittedly as some have stated, a bit slow to react, but after a few more minutes, reaction time vastly improved. It is now instantaneous as soon as it sees oncoming vehicles. The above may be coincidental regarding the setup, as a final point I have set it on recommendation to North America within the Gap iid config files. I have found it comparable with the setup on my 7 series BMW.
Post #615686 10th Dec 2021 2:12pm
Sonearly
Obviously set up in the vehicle setup on the instrument cluster o right hand drive
Post #615687 10th Dec 2021 2:13pm
Bl4ckD0g
Its odd, I've never found it slow. It is a bit rudimental where the Mercedes intelligent light system makes some really nice transitions, but I've found it plenty fast enough to react.
Only people flashing are those where they can't even see the car yet, but see the lights around the bend. I'll let them get with the times and realise that for many cars it is automatic once I (the car) sees their lights as well.
Post #615706 10th Dec 2021 3:53pm
Ansi
Switzerland 2010 Range Rover Autobiography 5.0 SC V8 Adriatic Blue
I found it also to slow on my 2010/11 but funny enough it's not even working anymore. While the startup check, the green light on the dash light up but it just doesn’t bother to work anymore.
Trouble I have is I want "things" working even if I don't use them. Whistle
I may have to configure it out and then in again!?
Post #615751 10th Dec 2021 7:29pm
