Home > Technical (L322) > High beam assist
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Mine does that. I can see the light then it goes off again.
Post #615753 10th Dec 2021 7:34pm
darrenm
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
What setting have people changed using iid tool to make it work
Post #616019 12th Dec 2021 5:13pm
kooky_guy
Mine's turned off as it's too slow to react. I'd be interested in recalibrating it though to see if that improves it. We have it on our X-Trail and on that it is excellent.
Anyone know why all these systems switch off at lower speeds? Is there some regulation governing it? I can't imagine why there would be, but all the cars I've driven with this system turn it off below about 20mph (often just when you need it on narrow country roads).
Any way to change this setting? 2010 4.4 TDV8 Vogue SE
Post #616329 14th Dec 2021 12:52pm
Bl4ckD0g
I always assumed that it’s linked to typically being in a build up area. It would be seriously annoying for people living their to have their homes constant in full beams lit up. If you drive so slowly on such country roads (yup animals I get that around our home) then just use it manually. You should not come across many other cars, and also get plenty of warning if you do.
Post #616416 15th Dec 2021 3:48am
comports
Mine has the High Beam Assist but i am able to turn it off in 2 ways.
1. Using the menu options in the dash (you can also select driver left or right - still not sure if thats asking if I 'drive' on the left or 'sat on the left' in the car Question )
2. With the dip beam on you see the auto illuminated under the headlight symbols in the dash. Push the left hand stalk away (as if manually operating full beam) and pull it back to normal and you turn the auto off - not sure if it resets itself on restarting the engine though.
I guess turing it off is differernt to diabling or enabling it though. Ash
2016 SDV8 AB
Post #682148 8th Jan 2024 3:22pm
D3Jon
Re: High beam assist
JamesDarby wrote:
Is high beam assist standard
On my car when on auto. The lights switch on but you just get the green side light on the dash, or the blue main beam. There is no green dipped.
The afs works on dipped. I don’t see any option to turn high beam assist on either.
Is this a fault or an option I don’t have.
Thanks
James
As stated by others, your car would need to have been specified with the Vision Assist Pack, so you'd also have headlights that turn with the steering wheel above 10mph or whatever minimum speed it is, as well as 360 camera's and blind spot monitoring.
If you do have it, then scroll through the menu on the instrument cluster and you'll find an option to enable or disable it. Thumbs Up
My Vogue SE with a load of other exta's had it, and to be honest I had it turned off. It was hopelessly slow to respond and blinded every oncoming driver. Rolling Eyes
My new Volvo has auto main beam / headlights, and with it's mega 'burn every oncoming driver's retina's out' LED lights I also have it turned off, so still crap on a much newer car! Rolling with laughter
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #682169 8th Jan 2024 5:43pm
