![]() | Home > Technical (L322) > High beam assist |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
It came with the vision pack on the autobiography. For it to work you need to switch on your full beams. You then will see the great symbol with auto on the digital dash at the top right. |
JamesDarby Member Since: 29 Sep 2021 Location: Rugby Posts: 25 ![]() ![]() ![]() |
Thanks. That’s why it doesn’t work then as I haven’t got that option.
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
Can it be configured ? onto no6 Range Rover
Yup, if you have it on the car. Mine was working, but after playing with the CCF configuration I've managed to disable it |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Retro fitted mine, operation seems different to what is stated previously. I just need to turn to auto on the switch and do not need to select full beam. The “auto” above the Green Headlamp symbol comes on when the ambient light switches on the lights. As side observation when configuring the files I was advised to set to North American. For some reason it appears to be more sensitive than on my previous L322. |
Interesting. Perhaps it’s different in that setting. But I’ll try it out. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes as stated above but you will obviously need to change the rearview mirror to the one with the camera on the underside... You will also need the plastic surrounds as they are different on the camera'd mirror ![]() |
BlackStang5point0 Member Since: 03 Sep 2021 Location: Co. Durham Posts: 14 ![]() ![]() ![]() |
That's how mine works just leave lights on auto and the high beam comes on automatically. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3203 ![]() ![]() ![]() |
No need to touch anything to make it work on our 2012 either. However, it always seems slow to respond. When a car is coming towards you they can often end up flashing at you before it's dimmed so I more often then not end up dimming the lights manually.
misfire84 Member Since: 25 Nov 2020 Location: brecon becons Posts: 37 ![]() ![]() ![]() |
I Agree the high beam assist is too slow to stop the oncoming driver flashing you , l322 2012 2012 Black 4.4 TDV8
I had read that the system needs to be calibrated to work correctly, this should be during the original build but conditions may not be the best in the factory. Apparently it is self calibrating when first powered, when installing mine I took it for a drive as soon as it was configured, initially it did not seem to work but after a short drive it began to work, admittedly as some have stated, a bit slow to react, but after a few more minutes, reaction time vastly improved. It is now instantaneous as soon as it sees oncoming vehicles. The above may be coincidental regarding the setup, as a final point I have set it on recommendation to North America within the Gap iid config files. I have found it comparable with the setup on my 7 series BMW. |
Obviously set up in the vehicle setup on the instrument cluster o right hand drive |
Its odd, I've never found it slow. It is a bit rudimental where the Mercedes intelligent light system makes some really nice transitions, but I've found it plenty fast enough to react.
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 150 ![]() ![]() ![]() |
I found it also to slow on my 2010/11 but funny enough it's not even working anymore. While the startup check, the green light on the dash light up but it just doesn’t bother to work anymore.
