![]() | Home > In Car Electronics (L322) > replacing the 2010-2012 head unit |
Goulime Member Since: 11 Jul 2020 Location: Paris Posts: 2 ![]() ![]() ![]() |
Is there a hdmi input or hd aux for rear screens ?
alaahnx Member Since: 15 Jul 2020 Location: WI Posts: 13 ![]() ![]() |
Hi and thanks for the very helpful discussion.
Harvenberg Member Since: 09 Apr 2020 Location: Stockholm Posts: 23 ![]() ![]() ![]() |
*Bump
LowB Member Since: 23 Jan 2021 Location: Farnham, Surrey Posts: 35 ![]() ![]() ![]() |
https://1drv.ms/b/s!Anbn_TnNZULngd5f75sl-_1bh8fcOg Hopefully the link works.
bigben Member Since: 12 Nov 2021 Location: Northampton Posts: 17 ![]() ![]() ![]() |
Considering doing this. Is the forum discount still available? 2011 TDV8 Vogue
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
I've had my Naviplus installed for about 18 months and am still very impressed with both wired and wireless apple CarPlay (I've not tried Android so can't comment on that). I especially like that it is fully touchscreen enabled unlike other alternatives that use a joystick.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Just a few observations:
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3788 ![]() ![]() ![]() |
Are you saying that an updated Naviplus is now supplied that does not require opening up of the head unit, merely plugging and unplugging connectors ??
Still need opening the head unit; only 8 screws plus the screws of the brackets. Then simply disconnect the two connectors and insert the bypass/overlay connectors, and screw it back together. It will take you longer to take the opportunity to clear the screen and remove that patchy coating from it |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
@Mike, did you not have one of these kits a while back? ... - .- -.
I bought one believing that it was plug and play installation, and that I would be able to cope with the job, but when it arrived I studied the installation instructions and realised just how much work was involved to fit it.
i thought it was something like that Mike.. |
I think intellidash is expensive compared to just have a phone holder and a bovee.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3550 ![]() ![]() ![]() |
just watching tis from Simon:
