Home > In Car Electronics (L322) > replacing the 2010-2012 head unit |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8334 |
He gave me $100 Australian dollars discount, with wireless, steering wheel adaptor and postage it worked out to around £700 depending on the exchange rate...
8th Jul 2020 7:32pm |
WB Member Since: 26 May 2016 Location: London Posts: 303 |
They're selling well at this price so makes sense I think. It’s cheap compared to what LR would charge! Its also slightly more expensive but far superior to their main american competitor which doesnt do touchscreen or wireless carplay and from what I’ve read is a pain to install with poor support.
8th Jul 2020 8:59pm |
Pas153 Member Since: 04 Nov 2019 Location: West Yorkshire Posts: 20 |
Can’t argue with the pre sales support, they’ve got back to me almost straight away every time I’ve been in touch, even well outside office hours. Coupled with WB’s ringing endorsement, I’ve pushed the button. Now got to find the right time to tell the missus why the echo auto we bought a week ago is surplus to requirements! |
9th Jul 2020 5:36pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Really quite curious about this. As I understand it, the system mirrors your phone but leaves the original system in place. That being the case it isn't any different in result from the Navtool offering with similar or cheaper cost.
9th Jul 2020 6:34pm |
HI John,
9th Jul 2020 7:13pm |
WB has covered this really well, but I’ll add my twopenneth! I too looked at the US option but with the joystick and no touchscreen option, it seemed like an add on to retain the existing system without the actual convenience of CarPlay. Yes it was less expensive but seems to be, effectively, a video interface.
9th Jul 2020 8:47pm |
Thanks for the replies As I said, it appeared to be the same but obviously, from the description, there are differences. Tks. John
10th Jul 2020 6:51am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3545 |
do I understand this correctly: the Naviplus switches to carplay from 'normal' with two presses on one of the steering wheel buttons ?
10th Jul 2020 6:33pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3780 |
Greg,
10th Jul 2020 6:50pm |
To switch from the factory headunit functions to the CarPlay it's a long hold on the Call End button on the steering wheel. The optional steering wheel control allows you to skip tracks forward and back using the steering wheel control. Volume on the steering wheel works without this as the audio from the CarPlay is channeled through the car's existing AUX input. |
10th Jul 2020 7:23pm |
Interesting... So even without the additional steering wheel functions, it still taps into the canbus.
10th Jul 2020 8:09pm |
Yes you have to splice two cables into CAN+ and - behind the dashboard so things like switching input to the Reverse camera is automatic and it can pickup the long press on the call end button. I’m assuming the CANBUS connection does other things too.
10th Jul 2020 8:37pm |
and... last question - you said WB it taps into the AUX - do you know does that prevent you using the rear console aux in ?
10th Jul 2020 8:59pm |
You splice into the AUX left/right and ground wires so the Aux port in the rear remains fully functional. On cars with Aux detect (I believe this is those with uprated audio) there is an extra installation step to short the Aux detect wire to ground under the rear center console) - again the rear aux port remains fully functional. |
10th Jul 2020 9:20pm |
