Home > In Car Electronics (L322) > replacing the 2010-2012 head unit
Page 8 of 9 <123456789>
Goulime
France 2012 Range Rover Autobiography TDV8 Stornoway Grey
Is there a hdmi input or hd aux for rear screens ?
Thanks
Post #561101 12th Jul 2020 6:33am
GGDR
Going back to the factory set up, It's staggering how unbreakable the original system seems to be...
Many skilled folk have tried unsuccessfully to hack to update the maps on the HDD.
Anyway, I do wonder how the factory system can be added to without splicing and piggy back plugs..
Mine has surround cameras, the menu comes up on the right had column on the home menu.
That alone, for those without surround cameras, should be a spare input you'd think.
And with this system on all LR vehicles of this era, plug Jags too there must be a huge market for a more plug in upgrade... Even a way upgrade the maps, let alone carplay.
. Cheers, Greg
Post #561103 12th Jul 2020 7:05am
alaahnx
United States
Hi and thanks for the very helpful discussion.
Could someone share the installation document so other members have an idea of how much skill/time is involved in the DYI?
Does anyone have an idea if they ship to the US? I contacted then a couple days ago but have not heard so far.
Would be interested in a group buy/discount as well.
Thanks,
Post #563043 30th Jul 2020 3:32am
Harvenberg
Sweden 2011 Range Rover Autobiography TDV8 Nara Bronze
*Bump
I would also be interested in the install docs.
Post #584433 19th Feb 2021 11:43am
LowB
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
https://1drv.ms/b/s!Anbn_TnNZULngd5f75sl-_1bh8fcOg Hopefully the link works.
Here’s a link to the Naviplus installation manual for those who want to take a look. Certainly not a 5 minute job but doable if you have the inclination. 2011 TDV8 4.4 Vogue SE in Galway Green with Black leather
1998 Saab 900 turbo convertible in Lime Gold with black leather
Post #590614 7th Apr 2021 6:53pm
bigben
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
Considering doing this. Is the forum discount still available? 2011 TDV8 Vogue
2007 TDV8 Vogue
Post #613838 25th Nov 2021 10:02pm
WB
I've had my Naviplus installed for about 18 months and am still very impressed with both wired and wireless apple CarPlay (I've not tried Android so can't comment on that). I especially like that it is fully touchscreen enabled unlike other alternatives that use a joystick.
100% recommend it and feel free to PM me put you in touch with the contact I have and he can offer you a discount.
Post #613869 26th Nov 2021 1:43pm
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Just a few observations:
* Current kits do NOT require any splicing or cutting or anything. They are full plug and play kits.
* The PDF linked above is for a single display, the dual display unit looks a little bit different.
* It really isn't hard to do, the only things to remember is that a pointed tool makes life so much easier to get the air vents out Smile And you really want to tug hard on those side dash covers, or use an interior tool kit.
* The rest is easy, well apart from me having no clue on how to remove one of the plugs from the head unit not even on the third time I done this procedure.
Wireless Apple CarPlay is just so nice. Android Auto works in the same way, it just is Censored compared to Apple and years and year behind in its UI....
All other functions of the car operate normally, nothing changes.
Post #614607 3rd Dec 2021 3:36pm
Baltic Blue
Are you saying that an updated Naviplus is now supplied that does not require opening up of the head unit, merely plugging and unplugging connectors ??
Post #614608 3rd Dec 2021 3:45pm
Bl4ckD0g
Still need opening the head unit; only 8 screws plus the screws of the brackets. Then simply disconnect the two connectors and insert the bypass/overlay connectors, and screw it back together. It will take you longer to take the opportunity to clear the screen and remove that patchy coating from it Smile
Not scary, no soldering or cutting required.
Post #614613 3rd Dec 2021 4:05pm
@Mike, did you not have one of these kits a while back? ... - .- -.
Post #614620 3rd Dec 2021 4:45pm
Baltic Blue
I bought one believing that it was plug and play installation, and that I would be able to cope with the job, but when it arrived I studied the installation instructions and realised just how much work was involved to fit it.
At the same time we had decided to move house and I had to concentrate all my time on sorting out the move so I sold it to a forum member who was more able to fit it.
I still like the idea of CarPlay working on the original screen, but have accepted that Installation of a Naviplus is way beyond me at my age, so settled for the Intellidash as a good easy fix.
If anyone was advertising a supply and fit service for Naviplus I would definitely jump at it.
Post #614625 3rd Dec 2021 5:04pm
i thought it was something like that Mike.. Thumbs Up
i dont think naviplus is in the UK...i believe its an aussie outfit and its stuff is expensive compared to the intellidash.. ... - .- -.
Post #614627 3rd Dec 2021 5:08pm
Bl4ckD0g
I think intellidash is expensive compared to just have a phone holder and a bovee.
I appreciate naviplus may be daunting, but seriously anyone who can operate a screwdriver can do it. The dash removal of the L322 was one of the easiest ever to get to the head unit.
Third time I had to do it, as the wrong part was delivered originally, I did it in a morning.
Post #614638 3rd Dec 2021 6:01pm
GGDR
just watching tis from Simon:
. Cheers, Greg
Post #619240 8th Jan 2022 10:11pm
