Home > My Range Rover > My L322 Project |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
17th Nov 2021 12:14am |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
All my fluids are nearly done now with the exception of the engine oil which was done in June by previous owner and I intend on doing in December, the next one to tackle is the transfer case.
17th Nov 2021 8:37am |
As you may have seen from my first post, the tailgate needed some attention before the rust created a hole and with winter approaching I made it a priority to get done.
17th Nov 2021 8:51am |
Headlight bulbs.
18th Nov 2021 1:34pm |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 |
Great work, and you're reminding me that the HID bulbs on my facelift 3.6 (with the same lights) are a bit pants, so I'll get some new bulbs as they'll be the originals. The LED lights for the main beams look good too. |
18th Nov 2021 6:44pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3108 |
That’s a big improvement. Have you got a link to the bulbs you used? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
18th Nov 2021 9:29pm |
Both the bulbs I got from Amazon.
19th Nov 2021 9:05am |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 541 |
Beam pattern looks wrong, where is the kick up to the left side to illuminate kerbs? Have you got it set to continental pattern by any chance? Drives:
19th Nov 2021 9:10am |
I have never checked the lever to change the driving mode, I'll do that!
19th Nov 2021 9:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
up for UK, down for euroland.. ... - .- -.
19th Nov 2021 9:36am |
Now rvbush has started me off! I cant see the beam pattern in the daytime and I have just fiddled with the levers which were both in the upwards position, but that shows a flat beam pattern (as per the photos).
19th Nov 2021 9:46am |
My front door speakers have blown (the spider has detached from the frame) so any bass sounds like a load of loose paper flapping about.
19th Nov 2021 9:59am |
Took the RR up to North Norfolk for a few days and she performed brilliantly, her first long distance and everyday use test since I got her.
24th Nov 2021 4:58pm |
That's a good result on rebuilding the prop.
24th Nov 2021 5:03pm |
