Home > My Range Rover > My L322 Project
Page 2 of 8 <12345678>
Bow down Bow down Bow down Thumbs Up
Post #612853 17th Nov 2021 1:14am
Caesium
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
Transfer case
All my fluids are nearly done now with the exception of the engine oil which was done in June by previous owner and I intend on doing in December, the next one to tackle is the transfer case.
At this stage I have already changed the fluid in both differentials, the gearbox, power assisted steering and the brake fluid.
You could put the car in extended mode and put a stand underneath as there is loads of room in this mode, I already had the car in the air so I did it at the time.
I used Smith and Allen Transfer Case 0753 oil.
The transfer case showing the fill and drain plugs
Draining the oil
The old oil was not in great condition
 Christian.
Current Cars
2011 Range Rover Vogue SE
2020 BMW M4 Competition
2019 BMW X4
My RR Blog: www.facebook.com/L322Project
or
https://www.fullfatrr.com/forum/topic61540.html
Post #612871 17th Nov 2021 9:37am
Caesium
Rear Tailgate Corrosion Repair
As you may have seen from my first post, the tailgate needed some attention before the rust created a hole and with winter approaching I made it a priority to get done.
As I am no good at bodywork I decided to get someone in to do it.
The rust on the surface was minor and the seam sealer underneath was trapping water.
Still got the badge to stick back on but it looks much better.
I also took off the interior trim of both upper and lower tailgate and sprayed a load of Dinitrol ML in there to stop it corroding any further. Good thing about Dinitrol is that it's easily wipeable off the paintwork when it drips out. Christian.
Current Cars
2019 BMW X4
or
Post #612872 17th Nov 2021 9:51am
dhallworth
This is a great thread Smile
It's quite satisfying knowing you've got it all done when you're finished! I need to look at my top tailgate but I'm not brave enough to start painting it myself I don't think. Laughing
Post #612879 17th Nov 2021 11:37am
Caesium
Bulbs Bulbs Bulbs
Headlight bulbs.
My HID's were looking a little dull and yellowing so I bought some OSRAM replacements.
If you do this, don't buy cheap knock off bullbs or you'll have all sorts of issues with overheating, beam pattern, dazzling, radio interference, CAN BUS errors etc. Stick with Philips or Osram.
They are D3S on my MY2011 so I went for OSRAM Cool Blue Intense Xenarc
The main beam aux lamp is halogen and they are very yellow, so I upgraded to some OSRAM LEDriving HL H7 bulbs.
The bulbs are dead easy to access, I didn't need to remove anything under the bonnet except the portals on the back of the headlight unit
This is the xenon lamp
This is the aux main beam lamp
These are the old vs new D3S lamps, new on the right. Notice the bubble in the middle of the envelope on the Philips one (on the left) has gone opaque.
New on the left.
These plus in and twist so the wiring is facing downwards, it's 1/4 turn only.
Next is the aux beam H7 lamps
Old vs New.
this is where it gets interesting.
there is a collar on the lamps that you need to take off, turn 180 and put back on and then it locks onto the body of the lamp and allows angle adjustment. Mine are oriented east/west for the two LEDs
Before I realised I needed to reverse this collar, I tried to insert the bulb as is and the collar fell off. Down into the engine bay. Big Cry
That required some intense searching, and then the removal of the undertrays in a vain attempt to find the collar as the bulb cannot be fitted without it and they're £70 a pair for new bulbs.
I replaced all the spire nuts and screws with stainless ones, much better.
Turns out the collar was not even down there, it was wedged down the side of the radiator on the bracket standing straight up. Bearing in mind this thing is like a big washer and not magnetic I am surprised I ever found it.
The collar is the black and silver bit
Nearside headlight changed, offside the old bulbs.
Beam pattern is still perfect and much brighter than before - nearside is new bulbs. Notice the beam intensity below the cut-off is much better on the nearside meaning more light on the road.
 Christian.
Current Cars
2019 BMW X4
or
Post #613034 18th Nov 2021 2:34pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
Great work, and you're reminding me that the HID bulbs on my facelift 3.6 (with the same lights) are a bit pants, so I'll get some new bulbs as they'll be the originals. The LED lights for the main beams look good too.
Post #613076 18th Nov 2021 7:44pm
dhallworth
That’s a big improvement. Have you got a link to the bulbs you used? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #613103 18th Nov 2021 10:29pm
Caesium
Both the bulbs I got from Amazon.
The HIDS
https://www.amazon.co.uk/gp/product/B01NA9...&psc=1
The LEDS
https://www.amazon.co.uk/gp/product/B07P5N...8&th=1 Christian.
Current Cars
2019 BMW X4
or
Post #613133 19th Nov 2021 10:05am
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Beam pattern looks wrong, where is the kick up to the left side to illuminate kerbs? Have you got it set to continental pattern by any chance? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #613134 19th Nov 2021 10:10am
Caesium
I have never checked the lever to change the driving mode, I'll do that!
Do you know if the beam adjustment lever up or down is UK as the manual does not state which. Christian.
Current Cars
2019 BMW X4
or
Post #613138 19th Nov 2021 10:35am
up for UK, down for euroland.. Thumbs Up ... - .- -.
Post #613139 19th Nov 2021 10:36am
Caesium
Now rvbush has started me off! I cant see the beam pattern in the daytime and I have just fiddled with the levers which were both in the upwards position, but that shows a flat beam pattern (as per the photos).
I'm going to have a play at night and see what pushing them down does. Christian.
Current Cars
2019 BMW X4
or
Post #613140 19th Nov 2021 10:46am
Caesium
Door speakers
My front door speakers have blown (the spider has detached from the frame) so any bass sounds like a load of loose paper flapping about.
I bought a set of reasonable cost Focal speakers (they're not 2ohm) and fitted them to replace the older H/K ones. I couldn't find 2ohm ones for less than 100 quid a set and as this is our third car, I'm not going to go mad.
They're Focal RSE-165. they came with a crossover and tweeter but I did not use either
Here's the Focal speaker next to the H/K
Desoldered the old speaker terminals and soldered in the new one
Soldering complete. Make sure you check the polarity of the speakers before fitting or you'll have phase reversed sound which will be really weird in a car with multiple speakers
While I had the door panel off I sprayed the interior with dinitrol only to be then informed the doors are aluminium. Never mind. Belt and braces eh!
Here's the speaker fitted into the door
Wider shot for perspective.
If you're doing this then get yourself some spare clips for the door panel from either LR or vehicleclips.co.uk as the generic ones simply don't hold and some of them will undoubtably break. Enjoy getting the door release cable back on. What a pain. Christian.
Current Cars
2019 BMW X4
or
Post #613141 19th Nov 2021 10:59am
Caesium
Propshaft Centre Bearing
Took the RR up to North Norfolk for a few days and she performed brilliantly, her first long distance and everyday use test since I got her.
I did notice a droning at speed however and I suspected it might be the propshaft centre support bearing so as soon as we got back i got her up in the air and dropped the prop.
This looks easy on first glance but it actually required me to drop the exhaust and remove two large heat shields which were a bit of a pain.
Here's the prop off the car, you can see the support bearing in the middle.
In the UJ in the middle there is a 17mm bolt and U washer that holds the two parts together, you can just about make out the bolt hole - bolt removed
The eagle eyed among you will notice the bearing is missing, this is because it was preventing me from getting a drift onto the end of the UJ to try and drift it apart.
This is what's left of the bearing. I cut it off with a grinder but left the inner race guide on the sleeve to protect the bearing face.
Repeatedly hitting the joint did not separate it, I ended up using an air chisel on the shoulder to drive it apart.
This is the face of the rear of the shaft, I had to run a flap wheel over it to remove the burrs caused by the striking.
This is the splined part. There are some documents that show you need to mark the two pieces of the shaft so they go back in the same position. I didn't find this to be an issue as the splined part has a keyway of two wide splines that means they can only be put back together in one way.
The part adjacent to the splined section is the bearing carrier section where the bearing fits, I drifted it on with a piece of pole.
Here's the tunnel with the prop out.
I put the prop back onto the car using loctite on all the bolts and torqued up as per manual. You'll need a decent extension bar to be able to get to all the bolts.
After putting the car back on the ground, I'm pleased to say the droning was completely gone, but I did notice something that was suggested by someone else, my offside rear wheel was quite warm..... Christian.
Current Cars
2019 BMW X4
or
Post #613696 24th Nov 2021 5:58pm
dhallworth
That's a good result on rebuilding the prop.
I read a lot of reports from people saying that rebuilding them never works properly and chickened out and bought a new shaft!
Sticking rear calipers are also common on these cars unfortunately.
Post #613698 24th Nov 2021 6:03pm
