![]() | Home > My Range Rover > My L322 Project |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 454 ![]() ![]() ![]() |
Here you go David, this is the wheel arch sealing strip I used. Fits like a glove.
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3181 ![]() ![]() ![]() |
I only bought 1 metre and that was enough for both arches. Christian.
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 606 ![]() ![]() ![]() |
Christian, why that style of rubber strip?
David, I used the type with the lip because the U type does not effectively stop dirt laden water getting between the wheel arch liner and the arch.
Thanks, useful information
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1291 ![]() ![]() ![]() |
I used the u shape rubber because I wanted to completely cover the wheel arch lip from stone damage. Water will still get behind any 'seal' unless you fill it with silicone or the like first.
The car is currently looking like this, can anyone guess what is being done this time?
Wheel refurb? 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
GraemeJudge Member Since: 10 Feb 2018 Location: Fareham Posts: 54 ![]() ![]() |
Converting it to run on rails 🚂 |
colalowe Member Since: 11 Jul 2021 Location: Lancashire Posts: 107 ![]() ![]() ![]() |
What a fantastic write up, I have had to change the same suspension components on mine, I also need to change the centre prop bearing and I’m just waiting on a gearbox flush.
Thanks very much for that, it's always good to see positive feedback. It helps to motivate me to keep documenting it! I'm not sure I'd have a flush on the gearbox BTW, I've heard mixed things and ZF don't recommend it. Christian. Current Cars 2011 Range Rover Vogue SE 2020 BMW M4 Competition 2019 BMW X4 My RR Blog: www.facebook.com/L322Project or https://www.fullfatrr.com/forum/topic61540.html |
ergobyte Member Since: 03 Apr 2022 Location: bordeaux Posts: 124 ![]() ![]() ![]() |
Hi,
