![]() | Home > Technical (L405) > front knuckle cracking |
FTP20 Member Since: 03 Oct 2018 Location: North Posts: 9 ![]() ![]() ![]() |
I am trying to understand if my VIN falls within the range that is understood to be prone to failure. FA218827 |
154JON Member Since: 31 Mar 2019 Location: Essex Posts: 131 ![]() ![]() ![]() |
In reply to Dijit post instructing people to report there failures to VOSA , VOSA no longer exists as it was closed down in March 2014 and was replaced by the DVSA . |
marsie Member Since: 30 Apr 2010 Location: sheffield Posts: 916 ![]() ![]() ![]() |
are earlier Vins definitely not affected? Mine is a 2014 car but has a 159*** vin number so in theory falls outside the vin range mentioned but is the same year as some of the cars that failed |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 774 ![]() ![]() ![]() |
I'm in the same situation as you Paul. Currently though, all the reported cases as far as we are aware, fall within the VIN range and are 2015, not 2014 variants. Kev
It was RagingRovers car that got me thinking, his is a 2014 but his vin falls within the listed range (204***) but it seems a big jump in numbers for the same year so I guess some are missing Paul
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
Anymore news from DVSA / LR? 405 AB exec seats Baltic and Cirrus
My first contact with the DVSA was 16/09/2021 and since then they have collected both front knuckles from my car and been in contact with JLR, i contacted them on 09/11/2021 to see if there was any update and there reply was "With regards to this issue, dialogue with the manufacturer is still ongoing. Unfortunately, I cannot give you any further information but just wish to assure you that DVSA are fully committed to reaching a satisfactory outcome." so they are still on the case which is good.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 707 ![]() ![]() ![]() |
Standard "Best Practice" in Engineering design (especially Automotive & Aerospace) is that no component that is subject to likely "wear & tear" deterioration can fail in a catastrophic / life threatening manner.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
The JLR Technical reply is indeed amazing. Essentially what they are saying is that catastrophic failure (with the risk of death or injury to vehicle occupants and others) can fairly be expected to occur to cars of a certain age and mileage, 6y9m/80,000mls or less. If they know that to be the case they ought to be specifying a preventative maintenance replacement of the affected parts at an age/mileage they believe safe, e.g. 5y/60,000 miles or whatever, especially when it is impossible to see a developing problem through e.g. inspection at annual services. Pawl is absolutely right that there ought to be a safety margin and even if they didn't know the potential problem when the system was designed they need to act now they know the facts. DVSA may bring about a necessary change of mind. Only Range Rovers since 1988 |
HI CS
'Solutions Executive' - you go to give JLR credit for that! |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2654 ![]() ![]() |
The cause cannot be wear and tear as there is no movement - it isn't a ball joint! |
goddo Member Since: 27 Oct 2020 Location: south Posts: 83 ![]() ![]() |
I think most people understand that it isn't a ball joint situation.
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1318 ![]() ![]() |
I wonder if any VIN's in that known range of failure's, were sent to the USA?
