Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
Smitch Member Since: 05 Oct 2021 Location: North west Posts: 40 |
10th Oct 2021 12:26pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2518 |
Your pipe attachment point looks dry to me.
10th Oct 2021 7:52pm |
10th Oct 2021 8:04pm |
MikeB. Member Since: 04 Feb 2018 Location: 29320 Posts: 3 |
Hi Nino, the yellow O-Ring on the picture is which part? What's the size of this one? Thanks for the answer!! Best regards MikeB. 2012 FFRR 4,4 TDV8 Vogue 2010 Defender TD4 2003 TVR Tuscan S 1998 TVR Griffith 500 |
24th Jan 2022 12:36pm |
nambFFRR Member Since: 06 Aug 2018 Location: United Kingdom Posts: 191 |
Evening
11th Jun 2022 6:31pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Best of luck sir... |
11th Jun 2022 11:56pm |
Oh well, oil cooler changed and the oil feed pipe o rings changed and apart from a few error codes being thrown up which seem to have settled down, I must have another oil leak somewhere else as I’m getting some oil smoke coming up from the back of the engine somewhere. Because it’s so congested at the back of the engine, I’m struggling to see where it’s coming from. Any suggestions on what else maybe leaking would be appreciated. I have wondered if I’m getting oil onto the exhaust somewhere……so the new investigation starts! Damn it. 🤨 |
9th Sep 2022 11:26am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3283 |
Could be oil residue left over from the leak still making it's way down the back of the engine. 2012 TDV8 Vogue (L322) |
9th Sep 2022 11:37am |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 |
If there's no oil being seen reaching the floor, I'd tend to agree with JayGee.
9th Sep 2022 1:36pm |
Thanks guys….appreciate your comments. Think I’m just going to have to take the pollen filter off again which is easy to do and use a mirror to see if I can spot anything else. I’m hoping is just residue (I wasn’t able to wash anything down when I did the oil cooler) and I know oil seems to linger a long time so I might just have a slightly smoky engine bay for a while. If I spot anything obvious I’ll post what I found….. |
9th Sep 2022 2:55pm |
It’s easy to have a good half a litre of oil go down the back when changing the cooler! Really should try cleaning it off or it will burn for months!!! |
9th Sep 2022 3:47pm |
garyRR Member Since: 13 Mar 2021 Location: Hampshire Posts: 1480 |
First time I've ever seen this thread so, curious, I went and had a look. Also thank you because, should I get a leak in future, I'll use it as an initial point of call.
9th Sep 2022 6:41pm |
Thanks for your reply. I’ll try and give it a clean over the next week when I get the time 👍thanks |
10th Sep 2022 10:40am |
Jamesonfox Member Since: 06 Sep 2022 Location: Wales Posts: 22 |
@mm289 - If oil is in the coolant, can this be fixed by replacing the two gaskets on the oil cooler? Or must the entire oil cooler unit be replaced instead? |
19th Oct 2022 9:33am |
