Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 30 of 38 <123 ... 293031 ... 363738>
mattgage
United Kingdom 2011 Range Rover Vogue TDV8 Orkney Grey
No I didn't want to have to go deeper and disconnect the other end of the pipe so just changed the O ring, which works fine. I also changed the whole oil cooler unit instead of the gaskets and it's still all fine a year on. Hope yours the same.
Post #588908 25th Mar 2021 4:26pm
Tattiepicker
United Kingdom 2011 Range Rover Vogue TDV8 Mariana Black
just finished replacing the gaskets on my oil cooler. Also had to replace the water outlet connection after I snapped the top pipe into it, new part was £45 from Land Rover. What a difference in the performance and responsiveness after cleaning the inlet plenum, throttle body and MAP sensor.
Post #592845 1st May 2021 6:30am
Privanthe
So my new 4.4 is damp with oil underneath. Went for it anyway as it was the second I saw with the issue.
Can anyone just double confirm for me please that this is an o ring leak like I suspect?
Post #598579 24th Jun 2021 11:13am
stevepen
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Yes, that's the one. I changed mine a couple of weeks ago. 2011 Vogue SE TDV8
Post #598585 24th Jun 2021 11:56am
Privanthe
So my next silly question is;
Easiest way to get in there to change it? Step ladder? Kneel on the block?
Post #598586 24th Jun 2021 12:11pm
paul70
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
It was a small step ladder for me as I'm only 5ft 8!
Post #598587 24th Jun 2021 12:19pm
stevepen
Small step ladder and I put the engine cover back on so I could lie flat on the engine. 2011 Vogue SE TDV8
Post #598591 24th Jun 2021 1:20pm
Fox889
Could also be the oil cooler.....just to put a dampener on things....sorry😃 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #598595 24th Jun 2021 2:27pm
rjff
Privanthe
I suggest doing the o rings first followd by a good clean up of the area. If the oil does not reappear then it's fixed. If it continues to appear, then it may be the cooler gaskets.
IIR folks on here saying the o rings are a half hour job. The cooler is several hours teardown.
Be sure to use Viton o rings as all on here suggest.
HTH. Cheers
Richard
Gap IIDBT
Post #598604 24th Jun 2021 4:06pm
Privanthe
Thanks all. Will do all recommendations and see how we go.
Post #598624 24th Jun 2021 7:54pm
Privanthe
Is there any specific torque you must do the feed pipe up to, or is it ‘tight is right’.
Thanks
Post #598744 25th Jun 2021 2:44pm
rjff
I THINK the figures are in the WM. Search
workshop manual/engine/engine description/stats and spec.
If I am right the figure in on the last page, oil feed to turbo stub pipe banjo bolt. BEWARE, the bolt goes into an ali casting. Cheers
Richard
Gap IIDBT
Post #598785 25th Jun 2021 7:32pm
Baltic Blue
I can’t picture how you can get a torque wrench and socket anywhere near it, but look forward to seeing any pictures to prove me wrong.
Cheers
Post #598788 25th Jun 2021 8:11pm
GraemeS
Tight enough not to work loose is all that is required. Thread locker is a better option than over-tightening if you're unsure of what is needed.
Post #598811 26th Jun 2021 12:03am
Privanthe
Thanks everyone.
Feed pipe rings replaced this morning with the recommended ones. Easy job. Never had to climb into an engine bay before though. Hardest part was getting the pipe back in after, lovely and tight with new rings on.
Old rings felt like hard plastic and snapped like plastic would when taking off. Absolutely rock solid.
Post #598881 26th Jun 2021 6:43pm
