Home > Technical (L405) > front knuckle cracking
Page 8 of 45 <123 ... 789 ... 434445>
GraemeS
A nyloc nut is meant to be single use even though many people, including myself, re-use them.
Post #606770 19th Sep 2021 1:59am
Wonder how easy it would be to simply knock out the nuts and bolts and swap for new every 10k…. There is nothing that can't be fixed with a hammer😜😜
Post #606782 19th Sep 2021 8:56am
I had a tube of this on the boat, it is excellent and does what it says, it would certainly prevent the problems on this thread, as I said some pages ago, just add this joint to your service schedule and the arm should outlive the car....
http://www.acf-50.co.uk/marine.htm
Thumbs Up Pete
Post #606792 19th Sep 2021 11:44am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
Is the corrosion that's occurring on the ball joint rather than the bolt? If so, replacing the bolts wont help and in fact it doesn't look like the bolts are failing?
Post #606809 19th Sep 2021 2:33pm
154JON
United Kingdom 2015 Range Rover Vogue SDV8 Santorini Black
I have not seen any white corrosion on the bolt that secures the top balljoint or in the hole where the top balljoint bolt goes or on the surface of the balljoint, the only build up of the white substance corrosion is on the surface of the hole in the top of knuckle where the top arm balljoint goes.
It might be nothing to do with corrosion it could be there was not enough aluminium knuckle around the top balljoint on the origional knuckles, hopefully there will be an official answer to that question one day .
Post #606811 19th Sep 2021 3:26pm
knwatkins
I assume that the white corrosion is aluminium oxide. It's interesting that this is only impacting 2015 vehicles in the VIN range 195780 - 228236, as per the Russian video, despite the profile of the knuckle (small head) on earlier 2013-2014 vehicles appearing to be the same
The only thing I can think of is that there was change to the composition of the aluminium alloy which has been traced back to VIN range 195780 - 228236. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #606815 19th Sep 2021 4:30pm
knwatkins
More examples on the Russian L405 forum... http://lr-club.com/index.php?showtopic=157106 Kev
Post #608052 3rd Oct 2021 2:44pm
154JON
Morning kev
That link takes you to a log in page in Russian.
My update with the case is that Land Rover want nothing to do with me and don't seem to care that they have thousands of vehicles on the road with these knuckles on but the DVSA are taking it a lot more serious as i have a guy coming from the Vehicle safety Branch of the Driving and vehicle Standards Agency tomorrow to collect both the front knuckles from my car so they will be able to see the broken one and the one that has not failed.
Hopefully at some point this topic will be made public and will reach people ouside of Range Rover forums as it could save serious injuries as the vehicles with affected knuckles get older but it seems it will take a failure of the knuckle at higher speed before Land Rover want to take notice as so far all the cases that we know of seem to be at low speed or they have been found before they have failed.
Post #608157 4th Oct 2021 8:06am
knwatkins
Yeah, you need to sign in too see the thread Jon. If you use Google Chrome, it will auto translate the Russian. I have a look on that forum every now and again and the post caught my eye.
It's a real shame that LR are not recognising this as a serious safety issue that requires resolution. I'm not surprised however. Will it take death for them to admit there is a serious safety concern here?
I hope DVSA really press on them hard and thanks to you for persevering and raising the issue. Kev
Post #608223 4th Oct 2021 6:27pm
Ragingrover
United Kingdom 2014 Range Rover Autobiography SDV8 Nara Bronze
I've just had the same failure, on a motorway !
https://www.fullfatrr.com/forum/topic61465.html
Post #612136 9th Nov 2021 5:01pm
154JON
HI
This is the email you need lradvice@jaguarlandrover.com , it is for the Customer Experience Centre.
Post #612280 11th Nov 2021 9:14am
154JON
Just noticed its the same as the one you tried but it works for me and you should get an automated responce that says they will reply within 2 days.
Post #612282 11th Nov 2021 9:19am
Ragingrover
Update:
Got a call from JLR this morning and they (at the moment) taking my complaint seriously and say they want to look into it with a view to helping me.
Lets see what happens. DVSA has also responded and will be contact again soon.
Post #612423 12th Nov 2021 3:54pm
154JON
I went throught the procedure with DVSA and they collected the knuckles from both sides damaged and undamaged for testing but nothing from them yet, i refused to drive it without the other side being repaced as i got away with the first faliure and it was not going to get another chance of getting me at full speed as the first one was at about 5 mph, i have twice been told by JLR Customer Experience Centre that they can't cover the cost of my repair as it was not done at one of there franchises but it could not be done at there franchise as there was no space when the AA man called colchester Land Rover to book it in which was not a surprice as they had refused him taking a 2 month old L405 the day before due to workload.On JLR Customer Experience Centr 2nd refusal to cover the cost of repair which was 2 days ago i advised them as of the time and date of my email i was advising them that there was a safety issue with the knuckle at the point at which the top balljoint was clamped on all 2015 Range Rover L405 and i was then told its been raised within the Jaguar Land Rover Customer Solutions Team and a Solutions Executive will contact me in order to discuss further within 72 working hours but i have not heard anything yet and it does give them untill 14.06 15/11/2021, i would be very interested to hear how you get on as the person that started this topic was also refused and yours sounds the most positive yet .
Post #612434 12th Nov 2021 5:35pm
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
Do not hesitate, go straight to VOSA with this. They will investigate and if its common force JLR to do a recall. That might well save someones life.
I've used them on a continental brand and they took it seriously. They were very helpful. Just do it! Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #612473 12th Nov 2021 9:57pm
