![]() | Home > Technical (L322) > Removing CVD dampers and replacing for standard |
jeremy156 Member Since: 05 Nov 2024 Location: Southampton Posts: 6 ![]() ![]() |
Sam, did you go ahead with this in the end? Was expecting to find a video about it... ![]() |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 655 ![]() ![]() ![]() |
I'm getting a bit fed up of the harsh ride on my 2012 Westie, I feel every bump in the road, and it's quite bumpy over speedbumps whereas my 2006 car was fairly floaty, maybe too much so.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1299 ![]() ![]() ![]() |
If you want a floaty front end then fit some Dunlop struts and bags.
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 70 ![]() ![]() ![]() |
I feel exactly the same as Andy roo. The ride quality on my 2011 4.4 with 95k on the clock is horrendous compared to my previous 2005 l322. I am also looking into the possibility of replacing my shocks with standard old school ones. The other problem is the ride quality issue is unpredictable,occasionally the ride can be fine then the next journey it’s back to the bone shaker ride again. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2650 ![]() ![]() |
The shocks will be at their firmest if the sytem is disabled, which is easy to do by unplugging a front shock's electrical connector. If the ride isn't much different on other than very smooth surfaces then unless the CVD system has a hardware fault causing incorrect operation of the valves, the shocks are worn-out and unable to smooth the ride. Note that air-springs don't provide any damping, unlike steel springs which do, so if a shock isn't damping on even the smallest of shaft movements then the ride will be harsh.
TorontoDee Member Since: 27 Sep 2022 Location: Toronto Posts: 79 ![]() ![]() ![]() |
Do just the front shocks get swapped out or do the air springs also have to be replaced with them at the same time 2012 Supercharged L322 |
Hi, I can't help feeling that I'm following the route of Sam of Sam's Motor and Machine, I've been going through his videos recently and almost every step is Deja Vu, that's just like mine etc..
Mine came to me with Arnott's already on the front as of December 2019. I've since had to replace the sway bars and bushings. I also replaced the rear with bilsteins about a year ago (which have been perfect). 2012 Supercharged L322 |
I have Bilstein rear CVDs which were fitted several months before the fronts were changed and I have no complaints with the performance of any. However Bilstein rear air-springs don't extend the extra distance of the later L322 shocks, with both torn apart in a short time even though Bilstein shocks were fitted.
My problem looks like it's the front end, I disconnected one of the turrets and drove around the block, the front seemed much the same, but the rear was noticably much harder.
I've decided rather than going all out I'll change the 2 front Height sensors, as I've read a number of posts where that turned out to go someways to fix the problem.
Replaced both front height sensors today, fixed my harshness problem completely, now back to wafting. In the end I used Aerosus units.
Also got me one of them there stickers, looking mighty fine.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster |
