![]() | Home > Technical (L322) > Removing CVD dampers and replacing for standard |
aljo Member Since: 04 Jul 2018 Location: west sussex Posts: 202 ![]() ![]() ![]() |
did you ever get to the bottom of this problem ?
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 726 ![]() ![]() |
Hi Aljo,
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2641 ![]() ![]() |
Did you notice any difference in ride after disabling adaptive dynamics? The ride should have been noticeably firmer but if not then the system wasn't working as it should. Once disabled the shocks are always at maximum firmness and therefore either something such as an accelerometer is providing false information making the system think that the vehicle is always cornering or similar effect for which the shocks are made firmer or the shocks are totally worn out, providing no resistance even at full firmness causing every little bump to be transmitted to the body through the air-springs instead of being absorbed by the shocks. However if the shocks are worn-out then the vehicle would also be very floaty. |
Great to read that you have made progress π
Yes I did Graeme,
Nice to hear from somebody else that thinks this suspension system is pants.
Which shockers did you go for ?
I've gone for a pair of dunlop shocks for the front and
I hope that the non-CVD shocks provide the ride that you're requiring. Ride quality is very subjective.
Hi Graeme,
Update time.
Just another quick update to this for anyone who goes down the same route.
Either unplug the module or remove its power fuse will stop it sending unrecognised/unsupported data on the HS canbus. |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
I have to say the D3 Iβm in at the moment with 243k is more comfortable than my 2011 ff with cvd. It feels like the cvd tense up too much, theyβre harder than my m3 was 1995 4.6 v8, green/tan (long gone)
