Home > Maintenance & Mods (L322) > 2012 TD8 Westminster, starter clicking
Burkie33
Intermittently starter clicks but won’t crank, it appears to happen when brake pedal is “soft”, if I pump the pedal to firm more often than not the starter cranks and the vehicle starts. I am considering starter replacement or brake light switch replacement 🤔🤔🤔🤔. I have tried to access the brake light switch but can’t find the way to remove the panel beneath the steering wheel. I’ve checked YouTube which shows older models that have a clipped “pull down” panel but the Westminster seems to be moulded. I have removed the lower panel but this doesn’t gain access to the switch. All advice gratefully received 🙏
Post #603445 11th Aug 2021 10:14am
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
It will be the starter motor, common problem on your model.
Post #603453 11th Aug 2021 11:17am
CS
The thread will probably be moved to L322 general or maintenance, but anyway, when my 2012 WM starter clicked and would not start intermittently it was cured by replacing the starter motor. It seems a very common fault. The brake light switch wasn't mentioned, and as it does not click it might be less likely to be the problem. Only Range Rovers since 1988
Post #603454 11th Aug 2021 11:17am
dhallworth
Another vote here for the starter motor. Our 2012 car is on it's third.
It's incredibly simple to change and requires removing nothing other than the engine under tray. You do not need to remove the wheel, arch liner or anything like that.
I bought a Denso from Euro Car Parts for ours that was just over £300. They were in stock in Glasgow too and since fitting it we've had no further problems.
Post #603456 11th Aug 2021 11:30am
Burkie33
Thank you 🙏
Post #603465 11th Aug 2021 12:23pm
Burkie33
Thanks 🙏🙏
Post #603466 11th Aug 2021 12:24pm
Burkie33
David.
Thanks David, I’ve been checking out starter removal on YouTube and some are removing a piece of exhaust and others heat shields and having issues reaching the top securing bolt……..is it really an easy replacement with just the bottom cover removed ? I do have access to a ramp. I really appreciate your help thanks, Burkie
Post #603468 11th Aug 2021 12:29pm
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Yes it’s relatively straight forward. If you’ve access to a ramp even better. Bit of a squeeze getting it out. I followed the you tube video and did it on axle stands. Spent about three hours including cuppas and rewatching bits of video!
Got a Denso from Opie Oils for £207…..just looked and prices a lot higher and out of stock currently 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #603472 11th Aug 2021 1:04pm
dhallworth
We've got a ramp in our workshop too and all we removed was the under tray. It's a squeeze and it does need to be manipulated but it will come out of the gaps in the subframe.
Post #603478 11th Aug 2021 1:48pm
Burkie33
Thanks 🙏
Post #603508 11th Aug 2021 5:44pm
Burkie33
David.
Thanks 🙏
Post #603509 11th Aug 2021 5:45pm
Burkie33
David.
Thanks 🙏
Post #603510 11th Aug 2021 5:45pm
Burkie33
David.
Thanks 🙏
Post #603511 11th Aug 2021 5:46pm
ffrr14
Australia 2011 Range Rover Autobiography TDV8 Orkney Grey
Can I suggest you try this pls:
When starting press the stop/start button . first then > depress the brake pedal. Let me know how that goes when you are having difficulty starting.
pd SOLD | Tuned MY 2011.5 Range Rover Autobiography 4.4 TDV8 Orkney Grey | e-diff | ACC
New Toy: Unimog U1550L/37
New : G350D
Post #603549 11th Aug 2021 10:44pm
Burkie33
I’ll give it a try thank you, however after reading all of the replies I’ve ordered a new starter that I hope will arrive tomorrow 🙏🙏…….I really appreciate all the help and advice I have been giver on this problem…….🙏🙏🙏🙏🙏
Post #603556 11th Aug 2021 11:36pm
