Home > Maintenance & Mods (L322) > 2012 TD8 Westminster, starter clicking |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
It will be the starter motor, common problem on your model. |
11th Aug 2021 10:17am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
The thread will probably be moved to L322 general or maintenance, but anyway, when my 2012 WM starter clicked and would not start intermittently it was cured by replacing the starter motor. It seems a very common fault. The brake light switch wasn't mentioned, and as it does not click it might be less likely to be the problem. Only Range Rovers since 1988 |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3068 |
Another vote here for the starter motor. Our 2012 car is on it's third.
11th Aug 2021 10:30am |
Burkie33 Member Since: 11 Aug 2021 Location: Dunoon Posts: 20 |
Thank you 🙏 |
11th Aug 2021 11:23am |
Thanks 🙏🙏 |
11th Aug 2021 11:24am |
Thanks David, I’ve been checking out starter removal on YouTube and some are removing a piece of exhaust and others heat shields and having issues reaching the top securing bolt……..is it really an easy replacement with just the bottom cover removed ? I do have access to a ramp. I really appreciate your help thanks, Burkie |
11th Aug 2021 11:29am |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 357 |
Yes it’s relatively straight forward. If you’ve access to a ramp even better. Bit of a squeeze getting it out. I followed the you tube video and did it on axle stands. Spent about three hours including cuppas and rewatching bits of video!
11th Aug 2021 12:04pm |
We've got a ramp in our workshop too and all we removed was the under tray. It's a squeeze and it does need to be manipulated but it will come out of the gaps in the subframe.
11th Aug 2021 12:48pm |
Thanks 🙏 |
11th Aug 2021 4:44pm |
Thanks 🙏 |
11th Aug 2021 4:45pm |
Thanks 🙏 |
Thanks 🙏 |
11th Aug 2021 4:46pm |
ffrr14 Member Since: 21 Apr 2021 Location: Sydney Posts: 187 |
Can I suggest you try this pls:
11th Aug 2021 9:44pm |
I’ll give it a try thank you, however after reading all of the replies I’ve ordered a new starter that I hope will arrive tomorrow 🙏🙏…….I really appreciate all the help and advice I have been giver on this problem…….🙏🙏🙏🙏🙏 |
11th Aug 2021 10:36pm |
