![]() | Home > Technical (L322) > P040D-00 (2F) EGR temperature sensor replacement |
MTG2020 Member Since: 24 Feb 2020 Location: Caerphilly Posts: 35 ![]() ![]() ![]() |
Thanks. I have been following your excellent write up to do the job, so I've seen this pic. I will try again tomorrow, whether permitting, once I have trimmed more off the top of the sensor. |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Have you moved both heat shields?
No only the rear one. The nut appears to be accessible, when I checked with my Endoscope. See pic.
I found the both had to move. A little bit of that second shield was fouling the socket
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
thinking about your RP... so no other error codes?
So, here's my story of woe.
Hi Mark, well the car looks great. Your attention to air leaks seems sensible.
Hi GGDR. The sensor is not going well.
This is the smoke tester. It's designed exactly for what I used it for. I opened up both the opposite air box and the the turbo inter-cooler hose. In both cases, the smoke came gushing through, so I'm pretty confident there are no leaks. |
and are you on a yellow or red DPF warning ?
It's went red last week, but I've been leaving the IID plugged in and get the "Mrs" to clear the dtc's, which is about every one or 2 minutes. It also pushed the red warning back to Amber. |
Ok so it seems simple to me - that is your RP.
BTW Think I'll ask Stan to put page 4 posts on a separate thread
