![]() | Home > Technical (L322) > Delayed Air Con |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4323 ![]() ![]() ![]() |
Any thoughts on this:
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
mine is the same i am just weighing up if i go to all the effort to change the valve is it worth just popping in a new compressor 2012 Vogue 4.4 TDV8 - Current
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
Although the valve on my compressor is sometimes slow to start,once it starts working,it keeps working correct.Low refrigent does what you have,works and the stop and you only get ambient,and after a while it comes back OK.First thing to do is have the gas checked. 2012 TDV8 Vogue SE 4.4 |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
I think the general thought process is that if you are going to the trouble of stripping down to do the valve, you might as well fit a new compressor whilst you are there. Shouldn’t have to worry about it then....
Cheers for the replies...I'll get it diagnosed. Good to know the fluctuation might be due to a leak.
Rob, I had mine serviced as it still had gas in it but had never been looked at. It was re-gassed about 6 weeks ago and no leak was detected. And i have to say when it comes on we all freeze!!
Mine was regassed about 2 years ago and no leaks were detected so I'm thinking it's new compressor time too |
System was drained and recharged. All good until machine asked for AC to be switched on.
TomP Member Since: 06 Jan 2021 Location: Surrey Posts: 7 ![]() ![]() ![]() |
My RR AC is all over the place. On hot days it seems to blow warm air. On rare occasions it might attempt to send some less warm air. On even rarer times it serves up some cold air. I've been reluctant to give the problem to my local fixer because of the spurious nature of the problem, but this thread has given me something to point at. Thanks a lot. |
Tom - take it to www.glenrands.co.uk LR Techs and brand new air con kit Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Thanks for the advice Rob. I've used MES near Cranleigh and found them pretty good engineers, although they're not RR specialists. Do you think their specialist knowledge - particularly of RR AC problems - will trump my usual, go to garage? |
Yes. Mines all fixed. New AC compressor and instant cold air |
Thanks Rob. I'll give him a call |
TOmP - I sent you a PM. Check your PMs folder - link along top "brown" bar below the L405 and L322 above |
