Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 26 of 42 <123 ... 252627 ... 404142>
Baltic Blue
Apparently I have got Beta access, so I will try the update over the weekend, but otherwise you will have to email Pat to ask for Beta access.
Post #591334 15th Apr 2021 5:20pm
DrRob
I guesses do so. Pat needs to control who has it installed it Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591349 15th Apr 2021 6:42pm
Range Rover L322
New IIDTool function
I tested this for Pat. It's brilliant. It works.
A few kinks to iron out but it does what it says on the tin.
Post #593545 7th May 2021 8:52pm
Range Rover L322
Duplicate post.
Post #593546 7th May 2021 8:52pm
Baltic Blue
What was your soot reading at the start , when you activated the forced regen ??
Does it have to be over 17.5 g, same as auto regen. ??
Mike.
PS,
I haven’t got round to upgrading my iid yet. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #593558 8th May 2021 6:22am
Range Rover L322
I started the regen at 16g.
Pat tells me it will work even on a Red DPF Full warning light, although I haven't tested that.
It will be good to confirm that works - if so it's the full solution.
Pat's done a great job.
Matt
Post #593645 8th May 2021 8:26pm
Dunc
2012 4.4 V8 - 25,000 miles
Hi All
New to FFRR ownership, owned the car for a year and absolutely love it - wished I had taken the plunge earlier.
HOWEVER, yesterday the amber 'DPF Full' warning appeared on the dash and having Googled it, and read every page of this thread, I'm now worried. I have done many 2-4 mile under 30 MPH school runs over the year, very few long trips. A thirty minute 50MPH run last night has not cleared the warning light.
I'm never going to start working down the list of faults to fix myself, its just not my thing, so here are the questions -
- Main dealer or independent specialist? Before you answer, I'm 4 hours north of Glasgow, 70 miles from the dealer in Inverness.
- Our local garage is very good, has diagnostic tools and lots of general knowledge, should I let them loose on the car?
I'm happy to travel a long way (everything is a long way) to get to the right person/business to get this fixed......
Thanks in advance
Post #593980 12th May 2021 11:55am
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I would be inclined to take it for another long run as that may not have been long enough to burn the soot level to below the amber light trigger point. Ideally if you have a nice long stretch where you can set the cruise to 55MPH that would be a good option. 30 minutes at this speed and with the coolant up to temp might be enough to finish off the soot burn to turn off the amber warning. 2011 TDV8 Vogue SE
Post #593981 12th May 2021 12:13pm
kevinp
I've had my car for over 18 months now and had never seen the amber light until last weekend when I was towing the caravan. After 7 minutes the light went out and has not returned. As suggested, go for a longer run.
Post #593983 12th May 2021 12:28pm
Baltic Blue
Also remember that you have to keep the fuel tank over the quarter full Mark., but as others have said, it can take quite a time to trigger a regen.
Post #593986 12th May 2021 12:47pm
Range Rover L322
Dunc,
Firstly don't worry, this issue is very likely not to be a big deal.
I agree with dennij and kevinp, Give it another, longer run at speed. Dont drop below 38mph. It will either clear or go red. 30 mins might not have quite cleared it. If it does go red not a big deal either, I drove mine for 20 miles on a Red once.
I would definitely go for a Range Rover specialist either MD or independent - they know what to look for.
For your calibration, if I were only to do the school run (3 miles) I would get a yellow once a month.
The easiest way to avoid this is to have one's wife take them every day in her Golf.
If it doesn't clear or goes red then make sure the Indy or MD to check MAF, MAP, then high pressure smoke test.
Good luck,
Post #594069 12th May 2021 8:57pm
paulparry82
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Barolo Black
DrRob wrote:
paulparry82 wrote:
Not yet - the garage I took it to couldn't do the test so I'm going to have to find one who can.
Paul - how's the DPF performing these days?
Did you find someone in your neck of the woods with a high pressure smoke tester?
Ta, Rob
Hi Rob, apologies for the lte reply - I mustn't have notifications set up, but funnily (annoyingly) enough the dpf has started to play up again! After a good clean of the MAF sensors and a few good long runs out the engine started to regenerate under normal driving conditions (with the IID tool I could see the passive regenerations taking place). So I never took it for a smoke test in the end (got tired of hitting dead ends with the garages I went to who never wanted to get involved - coupled with the engine seemingly now performing)!
With the COVID restrictions I found I wasn't really using the car much and was walking to work so my drives became more infrequent and shorter, and alas the problems have come back. Getting an amber warning last week, I tried to clear on the motorway but developed a red. Usual fault code (P2458-66).
I'm going to finally get round to changing the nylon hoses (I've been too busy to do so with buying a new house needing work and actual work work being obscenly busy). I'lll drop the oil and clean the MAF sensors too.
Cheers, Paul
Post #595933 31st May 2021 9:46am
Flintstones
Hi All,
Got the orange light of full bucket yesterday, checked the forum and took the car out for a steady run last night and at the light has gone.
Curious, when this happens does it clean it out completely or just enough to take the warning off?
Cheers,
Craig. Never trust a skinny chef
Post #597026 10th Jun 2021 7:39am
AJGalaxy2012
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Bonatti Grey
It does a successful full regen. BMW i3 Electric Car
2012 Full Fat RR 4.4 TDV8 (now gone)
2006 VW Touareg 3.0 TDi V6
Post #597039 10th Jun 2021 10:15am
DrRob
Flintstones wrote:
Hi All,
Cheers,
Craig.
You'll only know the true figure if you have an IID or similar plugged in and reading the values. If amber light has gone then relax and pour a beer Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #597060 10th Jun 2021 3:00pm
