Home > Maintenance & Mods (L322) > What to do if your DPF is blocked... |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
Can someone please post an IID screen shot of "normal" and "during an active regeneration burn" of the temperatures against the relevant sensors (Bank 1, Sensors 1, 2 and 3).
11th Jun 2021 9:18am |
Thanks. Was yours working properly when that was taken or having issues?
11th Jun 2021 9:39am |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
I was trouble shooting an issue at the time but from what I can recall, I've only ever seen temps of 600+ on bank 1 sensor 3.
11th Jun 2021 9:54am |
Glad you concur Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th Jun 2021 10:16am |
OK, this is non scientific but looking at the WM, I would guess (and it's only a guess) that the sensors are as follows :
11th Jun 2021 11:50am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3774 |
Rob,
11th Jun 2021 1:23pm |
Thanks
11th Jun 2021 2:39pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
I appreciate that this is a L322 thread, but for reference, this L405 video I posted recently may be of use to someone...
11th Jun 2021 2:51pm |
Rob,
11th Jun 2021 3:19pm |
KM Member Since: 07 Jul 2017 Location: Yorkshire Posts: 11 |
Just to reiterate my own experience with a 16MY L405....
14th Jun 2021 1:41pm |
Just an iid update.
14th Jun 2021 7:14pm |
Hi Mike, any news on when the DPF regen option is coming to the IID tool? 2011 TDV8 Vogue SE |
6th Jul 2021 7:58am |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
Not had the issue for a number of years. Travelled from Cornwall towing at the weekend 50-60mpg all the way. Went out today and amber light came on, put some fuel in, and took it for 2 runs of about 20 miles each way. Had to drop to 30mph roads after the 20 miles, and had a stop of around 20 mins before coming back. Would a longer run work? |
14th Jul 2021 2:37pm |
Ideally if you can get a run at around 55 60 MPH uninterrupted for 30 mins then your amber should go out (set cruise if you can). If the amber remains after this it may indicate an issue so check the usual suspects such as the 4 hoses on the intake plenum, give the MAP sensor a clean etc. 2011 TDV8 Vogue SE |
14th Jul 2021 3:12pm |
