Home > Maintenance & Mods (L322) > What to do if your DPF is blocked...
Page 25 of 42 <123 ... 242526 ... 404142>
GGDR
nice one mrmayhem. Thumbs Up
and welcome
. Cheers, Greg
Post #586563 7th Mar 2021 11:07am
DrRob
It's my turn to get the combined wisdom. Family friend, not me has an issue.
Symptoms: Getting frequent amber DPF warning. Once in last 2 months it spat out a little smoke. Turbo drain mod = not fitted but I've not inspected it with my own eyes yet (Covid)
Plan:
1) Smoke test for leaks. Pref high pressure but will take anything as first step.
2) Doughnut coming off for a thorough clean
3) Both MAFs in air boxes to cleaned
4) MAP on top of donut be cleaned
5) Boost temp sensor in intercooler to throttle body to be clean and clip/O ring inspected
6) 4 new silicone doughnut hoses to be fitted (I suspect this)
7) IID on order and monitor values for a week Thumbs Up
It took about 40mins to clear an amber last night and then appeared again today. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588544 23rd Mar 2021 2:46pm
DrRob
First code
New one on me. Workshop manual next Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588703 24th Mar 2021 1:52pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
Sadly I have seen this exact same issue as documented on this thread
https://www.fullfatrr.com/forum/topic54864-60.html
Still haven't got to the bottom of it but have had the turbo mod done, a new second turbo, new passenger inlet manifold and am now in the process of getting my DPF cleaned out, so I will follow this with interest. 2011 TDV8 Vogue SE
Post #588711 24th Mar 2021 2:26pm
DrRob
Live values as per our favoured fields
Post #588720 24th Mar 2021 3:54pm
DrRob
I'll join that thread now Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #588722 24th Mar 2021 4:17pm
Range Rover L322
Mr Mayhem - can you keep us up as to how your DPF performs now it's been cleaned?
Post #588925 25th Mar 2021 7:05pm
DrRob
paulparry82 wrote:
Not yet - the garage I took it to couldn't do the test so I'm going to have to find one who can.
Paul - how's the DPF performing these days?
Did you find someone in your neck of the woods with a high pressure smoke tester?
Ta, Rob Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #589806 1st Apr 2021 8:47am
Range Rover L322
From Pat at GAP:
Forced DPF regeneration is now ready for testing on the following platforms;
D4 & RRS MY10+ SDV6 3.0L and TDV8 4.4L
L322 MY10+ TDV8 4.4L
L405 MY13+ SDV6 3.0L and TDV8 4.4L
L494 MY14+ SDV6 3.0L and TDV8 4.4L
If you wish to give it a try, simply proceed with the following;
-Update the tool to Beta build 2764
-Menu--Service Test--Engine...
Post results on here or direct to Pat.
GGRR Glenn - this is your bag to test right?
Post #591144 13th Apr 2021 10:29pm
DrRob
Nice one! Bow down
Greg - you're probably the best person to test this for us Thumbs Up Bow down Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #591162 14th Apr 2021 7:55am
GGDR
Quote:
GGRR Glenn
Greg
. Cheers, Greg
Post #591164 14th Apr 2021 8:03am
GGDR
I have a DA-DPF Tool so don't need it (now).
Thx for posting Matt, good news it's finally out.
Somebody else will be along with a Red warning / full DPF in about..... five minutes!!! Razz
. Cheers, Greg
Post #591165 14th Apr 2021 8:05am
dennij
I don't see the option to download the beta file, just the standard build 2742 2011 TDV8 Vogue SE
Post #591167 14th Apr 2021 8:11am
RRDunc
England 2012 Range Rover Autobiography TDV8 Santorini Black
I only have the options for 3.00.00 B2728 (Release) or 3.01.00 B2697 (Special) - For Nav On Move update only
How do you get the Beta version?
Cheers,
Dunc. The life you have is the only one you'll get; make the most of it.
2012 4.4 TDV8 L322 Autobiography
2003 TD5 Oslo Blue D2 ES Premium Auto (with mods!)
Post #591301 15th Apr 2021 1:48pm
Baltic Blue
I have emailed Pat for help and will update this post with his reply
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #591331 15th Apr 2021 5:36pm
