![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
Anyone any ideas? I need help
Flintstones Member Since: 16 Feb 2021 Location: Newbury Posts: 20 ![]() ![]() ![]() |
I would love to do this.. but stripping the dash out to that extent - scares the willies out of me! Never trust a skinny chef |
It is actually logical and easy especially once you have done it once. The problem is that the instructions skip parts, as do the workshop manuals, and the online videos are all for other models not these late L322s. Oh and then there is the part where you need to pull on plastic parts that feels unnatural. And then once you are at the end there is literally one stupid connector that I’m stuck on for three days now. I really don’t want to put my car together again and give up, but I just don’t get this connector.
Ok I got that one. The trick to do this is to push it down, like it goes on tighter, and push the flexible ish part in. You can do that with one hand. Then with a screwdriver or other hard part you can wedge underneath the metal part and lift it out. So push down, in and out all at the same time. |
=dj= Member Since: 24 Oct 2020 Location: New forest Posts: 67 ![]() ![]() ![]() |
Oh wow, well done - I'm really pleased to hear you're past that wretched thing now!
Thanks |
jjfang Member Since: 13 Nov 2020 Location: Chicago Posts: 44 ![]() ![]() ![]() |
Have any of you guys had issues with the LVDS cable where audio suddenly only comes out one side of the vehicle? Ive had this system installed for a while now 6 months to a year and I was driving and all of a sudden my audio started to only come out from one side. Has anyone else experienced this? Im very close to just buying a new LVDS cable |
I'm doing the cabling part now, but my gosh the Naviplus instructions are absolutely shocking. They don't identify components supplied correctly, port names are different on what is provided compared to their instructions. Seriously one of the worst instructions I've ever come across. LOL Even the reference to the power cables is wrong, the instructions talk about power cable 7 and I've got a power cable 15. This really doesn't have to be that hard and for the money it should be a lot better.
The version of the LVDS cable to seems also different. I've got these rings as a separate cable attached. The instruction manual makes no mention of them at all. Did anyone else get this version? And if so what are they supposed to be connected to?
I'm thinking they've given me the wrong kit...The new touch film doesn't look like anything in the instructions either. And doesn't seem to line up at all with the additional board....
I really didn't want to do this, but |
Looking at the first image they've given me the Flexi connector for the old style board like what you had... |
Ended up figuring it out. Silly issue somehow the dumby aux I had in the aix port moved and that caused the sound to get altered all good. I’m fairly happy I didn’t have too many issues installing my only complaint is the static that happens sometimes when the system wakes up |
Cool. Glad you’ve managed to find the root cause.
