![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
TrevCOSS Member Since: 05 Jan 2020 Location: Plymouth Posts: 31 ![]() ![]() |
I’m very tempted, do you have to pay any import tax |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 113 ![]() ![]() ![]() |
Hi, There were no additional charges, delivery was very fast. 2011 4.4 TDV8
nearnshaw Member Since: 19 May 2020 Location: Leeds Posts: 4 ![]() ![]() ![]() |
Hi All - my first post on here but I have been using these forums for a while now, a great source of information as I've been doing lots of little jobs to my 2011 4.4 TDV8 - which TBH I've quite enjoyed!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3802 ![]() ![]() ![]() |
Nick,
Thanks Mike - will send you a PM. I'll try to photo and document as much as possible when I do it, if it works it appears to be a really good solution. |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Hi Mike,
John,
Ive the instructions for both single and dual view, Ive found that reading both is helpful when installing, will gladly send both instructions via PM. I would post them on here but not quite sure if I can post a PDF.
Andy,
shinchan Member Since: 05 May 2015 Location: santiago de compostela Posts: 109 ![]() ![]() |
Pas153 Member Since: 04 Nov 2019 Location: West Yorkshire Posts: 20 ![]() ![]() ![]() |
Apologies for my belated reply to this thread, I’m the chap that WB mentioned in his recent post and I am indeed, running around with the system installed and working. It was painful at times, but well worth the effort - its a vast improvement.
Markwood71 Member Since: 19 Sep 2019 Location: Dudley Posts: 31 ![]() ![]() ![]() |
The more important elephant in the room is.......... who am i paying to fit mine and how much !! |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 ![]() ![]() ![]() |
Hello |
I bought the kit recently and it now doesn't require any soldering or splicing into the loom, you simply have bypass plugs |
