Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit
Page 11 of 13 <123 ... 10 111213>
Ffrr-lover
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
supershuttle wrote:
I have no skin in this game having gone for the cheaper option (I only wanted Waze) but while googling I found this https://unique-ad.co.uk my son had one fitted in his Audi (he did get someone to install)
I think Craig got one and as far as I can remember he liked it.
On the surface it looks to provide the same functionality as the NavPlus units but at a lower cost. Does anyone know how the installs differ? Is there any reason to avoid this unit? Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2014 Audi Q7 3.0d (good riddance)
2010 L322 Autobiography 5.0 Supercharged
2011 L320 HSE 3.0 sdv6
2014 Jaguar XF-RS 5.0 supercharged
2007 BMW 535D
2005 Mini Cooper S
https://www.fullfatrr.com/forum/topic59478.html
Post #630591 4th May 2022 7:18am
Ffrr-lover
What about the Mode button???
These units take over the in built screen and send audio over the line input / aux input. A long press f a button allows you to flip between systems.
This appears to work well from the discussions and videos I see.
However, I assume the Mode button still functions? So when on the CarPlay screen and a clumsy button press catches the mode button does the audio source change? I suspect so, and then it’s a bit of a faff to get it back to the correct input?
Either switch to the old screen / system, and tap the screen… or learn the number of Mode presses to cycle through the options (probably several times as we will no doubt get it wrong first)
Just curious… Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #630592 4th May 2022 7:23am
Full-fat-Lance
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Orkney Grey
It looks like one of the only differences is that this is for single view screens only, not dual view. Other than that, it looks pretty similar.
I haven’t tried the mode button, but agree it probably will still change the source as expected. I’ll test when I go out in the morning.
Post #630642 4th May 2022 4:33pm
supershuttle
My son had his deinstalled (if that a word) because the top few pixels went off the top of the screen as fitted. He subsequently read of the fix on the internet but it was too late then. He really is a chip off the old block. Thumbs Up Geoff
Post #630686 5th May 2022 11:02am
Full-fat-Lance
I forgot to report back the other day… I tested and, as expected, the mode button still works whilst displaying CarPlay. I don’t think this is an issue though, you’d have to be pretty ham-fisted to press it by accident I reckon.
Post #630938 8th May 2022 12:50am
Ffrr-lover
Cheers for the update Full-Fat-Lance.
I wouldn’t consider myself ham fisted, but have only clumsily clipped it a couple of times. It’s normally cycled through quickly, and only makes the family jump when you get to the radio… as it’s loud static (im fed up of retuning after tweaking with my IIDToo) Laughing
As I said before, I’m just curious. I’m still getting either this or the naviplus unit at some point. Currently driving: 2012 L322 SE Overfinch 4.4 tdv8
Past rides:
2007 BMW 535D
2005 Mini Cooper S
Post #630950 8th May 2022 9:47am
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Seeking some help with my Naviplus install, if anyone could advise?
The system is installed, it all went pretty well and today I fired it up to see if it worked and it does, but, I have an issue or two:
1) The 'Range Rover' page no longer appears. I get a grey fuzzy screen until I use the 'hang up' button to change mode, and then the Naviplus system comes on.
2) Pressing and holding the 'hang up' button does nothing, the system attempts to make a change, makes a clicking sound behind the dashboard but ultimately shows the same screen again. I cannot get the original LR screen to come up at all.
I can't play any music from Carplay, although it looks like it is on-screen. The car is playing a CD from the autochanger that I can't stop...so it's like the car is stuck running its original system that I cant access.
Google Maps, WhatsApp and Spotify all appear normal. I've tried the dummy aux cable in and out, just in case it made a difference - it has not.
So the question is...what have I done wrong?! Did I need to plug in both the original ribbons? Not just the smaller one, 'A' denoted with a red star in the instructions? One original ribbon is not connected.
I have the dual-screen system, with pins 2,3,4 in the dow position - no other pins are down.
Any help would be much appreciated!!
-Tom 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #631703 15th May 2022 12:06pm
Full-fat-Lance
All original ribbons should be connected. Sounds like it will sort your issue. My guess is that you’re getting the CarPlay output as that bit is connected, but without the original connected it isn’t picking up the input to be able to pass it through.
Widest ribbon: the original goes into the new piggy-back connector on the cable that has taken its place
The one next to it has no modifications and returns to it’s original place.
The small one, again the original plugs into the new cable which took its place.
Post #631709 15th May 2022 12:29pm
TDV8_Tommy
Thanks Bow down , that was the issue.
It’s now fully functional and the car is back together.
I’m very pleased with the system Very Happy 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
Post #631757 15th May 2022 5:57pm
Full-fat-Lance
I’m glad you got it sorted.
It’s a great system and brings the car bang up to date. Enjoy!
Post #631766 15th May 2022 6:41pm
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Hi Tom,
So happy that you have it all installed and working now...
Very Best....
John 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #631930 17th May 2022 9:19am
TDV8_Tommy
Thank you, John.
I am extremely pleased, and it was a pleasure doing business with you Thumbs Up
Post #631933 17th May 2022 10:01am
flashheart59
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Galway Green
I’ve finally got around to fitting my Naviplus after putting it off for nearly a year. It’s not been anywhere near as bad as I thought but now everything is in it won’t boot past the Range Rover start screen. Dual screen 2010. If anyone has any ideas you could make me a very happy person!
Post #632889 25th May 2022 6:41pm
flashheart59
Ha! Plugged the CD changer in, all works! Kudos to the OP. Great forum.
Post #632897 25th May 2022 8:12pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Hi, Guys I have had the naviplus fitted by an in-car entertainment company very respected know what they are doing, They had the fitting instructions no problems.
I was asked to sit in the car to show me how it worked, the screen was there and working ok.
So the unit was working on the tech's android phone. I was asked to pair my iPhone, and that's when things went pear shape it would not pair? tried many many times
no joy.
The tech went to settings, then reset to factory settings to start again with no joy, and because I supplied the unit it was my problem I should contact Naviplus?
I have tried to pair my iPhone, with my wife`s iPhone, and it shows that it's paired on the screen
Playing songs giving directions for Waze but the screens are mixed with no sound and the touch screen function is not responding?
What is confusing me is it was working fine when the tech's phone was paired.
yes, it does have the dummy AUX plugged in.
Post #633318 31st May 2022 9:38am
