![]() | Home > In Car Electronics (L322) > Fitting my Naviplus / air play unit |
Andy2986 Member Since: 26 May 2019 Location: Suffolk Posts: 117 ![]() ![]() ![]() |
I can’t face working on it anymore today! But will have a look at that tomorrow 2011 4.4 TDV8 1998 D1 300tdi 1971 2 door Classic |
WB Member Since: 26 May 2016 Location: London Posts: 303 ![]() ![]() ![]() |
Definitely one for the FAQ then: whatsapp Steve directly for questions, do not email! For the wifi it needs to be enabled in the Factory mode settings. Also worth checking your firmware version as they had sent me a new one a couple of weeks ago and the wireless initial handshake is quicker and more reliable. Have you programmed the steering whee controls? That also needs to be done in the Naviplus settings. |
Ahhhhh,
Yes in the same settings menu where you swipe right - you can also change the logo and a few other bits.
Pas153 Member Since: 04 Nov 2019 Location: West Yorkshire Posts: 20 ![]() ![]() ![]() |
Hi both
Great news Dave, its definitely 2,3 and 4 to ON - mine is dual view too!! be careful to splice into the correct wires and if you have any issues whatsapp Steve or PM me and I’ll send you my number. |
Hi Dave
Great stuff, thanks again and I’ll no doubt be in touch! Very much looking forward to what looks like a great end product. |
How do you remove the head unit box without taking out the fuse board out of interest? The other reason I thought the fuseboard had to come out was to place the naviplus box behind it or did I miss a trick? |
Hi Will
And I know have wireless connection!
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3820 ![]() ![]() ![]() |
My box full of bits has just arrived.
TrevCOSS Member Since: 05 Jan 2020 Location: Plymouth Posts: 31 ![]() ![]() |
Does this work on the single screen display? |
When you order, you have to specify either Single or Dual view.
