![]() | Home > Maintenance & Mods (L405) > Land Rover Branded Dashcam Set VPLKV0134 |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4310 ![]() ![]() ![]() |
Simon at PowerfulUK has done an install vid into his new 110. He also mentions our very own Craig |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Yes, he installed his the day after I did... we obviously share pitfalls we have found... Clearly I couldnāt cover this in every video he makes or It would be a full time job! And his videos would loose some of their honesty/charm! ![]() |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 788 ![]() ![]() ![]() |
Other than an easy connection to the power supply, this kit LR dashcam doesnāt appear much different from the alternatives to fit, and the rear cam is still a PITA.
Phil, I took the same route as you through the rubber sleeve at the hinge point of the tailgate, however, I then removed the boot spoiler and fed the wire with the main loom across to the RHS of the tailgate. I then fed the wire down through the right side channel (again where the main loom runs) this is where my install slightly differs from yours Phil, the main loom exits into the void behind the boot light panel (the one you removed) I then drilled the panel installed a grommet for the wire to exit next to the camera position... IMHO it makes a slightly better install following the main loom across and down the RHS following the channel the loom takes. Then the wire is weather proof and you negate the need to drill the tailgate! š
Thanks Craig. Sounds like a decent alternative to a BlackVue.
Phil, take a look at the instructions on JLRās website as this kit has options when parked to be alerted with either GPS or GIRO etc etc, I know literally nowt about dash cams my friend... I bought this as we usually use this car for holidays and nice use so this is the one that does the most family miles, hence me thinking a dash cam may come in handy one day? And again for the security/theft reasons above... Iām sure the information on their site may have some of the answers to some of the settings your looking for? š |
Itās does appear to have a Parking Mode facility, which is excellent if it doesnāt drain the battery. From the instruction manual:
I will turn them on and report back re battery conditions in a few weeks Phil... š |
That would be great, thanks Craig.
Crikey! That seams dear! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
Ā£260'ish for that blackvue battery and Ā£360 for the LR dashcam!! ... - .- -.
Just wanted to come back with some thoughts after using the system for 2 weeks now... The first week was all about playing with settings and learning how to use the systems and then I have, I think? Now found the optimum setup for my usage... Week 2 i have left the car with a full battery (after leaving her on her JLR battery conditioner) from last Monday until today to see how the car battery would last. So, we had a meeting in Gloucester this afternoon. Went out to the car and opened it up and NO battery low message and she started just like normal... Yay! On the way to Gloucester, my good lady logged onto the app and saw that the only triggers this week have been posty and a couple of deliveries where the people have gotten close enough to start up the recording feature... So about 8 times rather than 80 the week before!!! |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3142 ![]() ![]() ![]() |
That's a nice neat install the way they've wired that into the light.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
I like the look of this one. Looking at the app made me think itās made by Thinkware. That not a bad thing as they make some of the best cameras.
