![]() | Home > Maintenance & Mods (L405) > Land Rover Branded Dashcam Set VPLKV0134 |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Yes you need to fit the wiring through the tailgate sir... |
bestman Member Since: 15 Jun 2018 Location: Hampshire Posts: 54 ![]() |
Had this fitted yesterday and the install looks neat enough.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35650 ![]() ![]() |
if like other dashcams you can change the recording time..normally 1,3,5 minute durations. ... - .- -.
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 791 ![]() ![]() ![]() |
Generally, the shorter the ‘chunk’ recorded the more reliable the recording. MY23 D350 HSE
why? ... - .- -.
It’s to do with the longer the recording session the more risk of any corruption affecting the whole recording. Break the recording down in to smaller chunks and save each chunk, then if one chunk becomes corrupt the others are safe. Here’s someone else explaining it:
Cheers Gents -
I’ve always been able to retrieve both the front and rear clips off the SD card. The file names usually have different extensions.
i doubt whether a £500'ish dashcam would have corrupt recordings.. ... - .- -.
I can see the clips, from both front and rear cams on the App, and download the same footage to the App under what appears to be the same file. But I can’t export from the app, and if I download straight from the SD card, the rear footage isn’t accessible.
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 ![]() ![]() ![]() |
Craig, any update on how the Land Rover Dash Cam is performing? I am weighing up the Pro's & Con's of fitting a Blackvue vs Land Rover OEM Dash Cam for my wife's new Defender |
Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 928 ![]() ![]() |
The LR dashcams are very good indeed.. |
pherplexed Member Since: 27 Apr 2010 Location: SC, USA Posts: 69 ![]() ![]() |
Craig - I’m working on this same install and I’m struggling to get through this tailgate part. How do you get the wire through the rubber sleeve without damaging anything? 2021 P525 | Eiger Gray |
zenman63 Member Since: 14 Nov 2021 Location: Warwickshire Posts: 164 ![]() ![]() ![]() |
Wd40 spray inside the rubber boot and the wires sale through |
