Home > Maintenance & Mods (L405) > Land Rover Branded Dashcam Set VPLKV0134
Page 4 of 4 <1234
Gremlin500
Shocked
but NOT the regular WD40, only the special silicone one, regular WD40 can turn natural rubber to snot, long term, not sure about Nitrile.
Better to use a squirt of IPA, which will do the job then quickly evaporate, leaving nothing behind to damage the rubber.
I use it as a temporary lubricant to remove handlebar grips on bikes, which can be a pig to get off otherwise. Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #657638 24th Feb 2023 1:06pm
pherplexed
United States
I’ve had this working flawlessly for a month or two now. However, the past two days it no longer powers on. Nothing has changed as far as I can tell. Overhead console is functional, no blown fuses.
Anyone had this issue? 2021 P525 | Eiger Gray
Post #663077 29th Apr 2023 7:49pm
Inigo
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Corris Grey
I'm having a complete mare with fitting the rear camera. Front camera is in and seems to be working OK. I've managed to get the cable as far as the rear tailgate. I have left my electricians fish tape and pulling lube somewhere else, annoyingly, and am struggling to work out how to get cable through to the tailgate itself. The rubber tube that leads to the tailgate splits further inside the tailgate. Presumably I am supposed to pierce the currently watertight sheath in order to get the cable through.
To make matters worse, while trying to dislodge the grommet at the body end, I think I broke the white plastic internal clip, so it no longer seats. Any suggestions as to how I can remedy this. Replacing the entire rubber tube might need me to dismantle and rewire everything in the tailgate.
I am slightly regretting not paying the extra to have it fitted by the dealer.
Post #701104 29th Sep 2024 7:25pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Getting the wire through the rubber grommet is a pain but doable.
The instructions gives measurements for drilling the tailgate I used an electrician rod to fish mine through, from the hole I drilled then pulled it back through. 2017 SDV8 4.4 silicon silver AB
2012 TDV8 4.4 Stornaway Grey AB
2011 TDV8 4.4 Buckingham Blue
2012 VW V6 3.0 Tougreg
Post #701119 30th Sep 2024 8:15am
Phil.
I removed both ends of the rubber grommet and the clip. As above you can then use a piece of wire or flexible plastic cable to pull it through. The grommets push back in place. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #701122 30th Sep 2024 8:49am
Phil.
This is how I fixed my rear dashcam - with photos:
https://www.fullfatrr.com/forum/topic55841.html?highlight=dashcam MY23 D350 HSE
Post #701123 30th Sep 2024 8:51am
Page 4 of 4 <1234
